Stromberg Cd150 Needle Valve
Sevent8mg Avatar
Sevent8mg Steve H
Henryetta, OK, USA   USA
Does the Stromberg Cd150 needle valve have a spring in it or does the fuel pressure hold it open? Mine was stuck open after the winter parking. I've cleanded it and It now opens and closes easily but wasn't sure if there was a spring in it to hold it open.
Did a search for an answer but couldn't find out this particular bit of information.
Thanks
76lucas Avatar
76lucas Gold Member Josh L
Floyd, VA, USA   USA
1978 MG Midget 1500
No spring (far has i know). Gravity makes it fall open. The tabs on the float make it rise shutting the fuel off. Once enough gas leaves the bowl it drops again more comes in. Rinse and repeat.
Fresno, CA, USA   USA
Steve. Give yourself TWO Gold Starssnowflake snowflake
Sevent8mg Avatar
Sevent8mg Steve H
Thanks Floyd and Joseph...2 stars on the sheet!!!
