bumps into hi beam
dogeddie Avatar
dogeddie Silver Member Andy L
Kaukauna, WI, USA   USA
Anyone else have a problem with the left branch off the steering column that switches low beam to hi beam, not staying in low beam position? Mine wants to "fall" forward into hi beams.
trevorwj Avatar
trevorwj Trevor Jessie
Louisville, KY, USA   USA
I don't, but IIRC there is a spring and detent ball involved. It might be repairable.
It was a Blast!
http://sprite-midgetclub.org/
dogeddie Avatar
It will click into place, but the slightest bump knocks it out. I probably shouldn't drive that thing at night anyway spinning smiley sticking its tongue out
trevorwj Avatar
Night drives in the summer with cool air are my favorite.
The cars are so low most drivers won't notice the high beams ... especially if they are the old incandescent ones.
It was a Blast!
dogeddie Avatar
Maybe I'll give it a go Trevor and see if I get flashed smiling smiley
not a good idea to be driving around, flashing your brights at people unintentionally, even if you think you won't bother them (trust that you WILL)
Get your lever fixed, they sell new ones at Moss, or if you don't need high beams because you don't drive at night, then unplug them to be sure (blue/white wire in front of the RH wheel).
N
trevorwj Avatar
Norm is such a party pooper. grinning smiley
It was a Blast!
CarverBoldman Carver Boldman
Kirbyville, MO, USA   USA
HA!
