Oil pan sealant
Mojan Mojan Norouzi
Fremont, CA, USA   USA
What you guys recommend as a sealant on oil pan gaskets? blue hylomar sealant?
Edited 1 time(s). Last edit at 2018-04-10 01:59 PM by Mojan.
PeterC Avatar
Madison Wisconsin, USA   USA
Here's a process I've had success using. A slight schmear of Hylomar on the gasket to pan surface. Invert pan on bench. Put a few cinder blocks on it and have dinner. Next day, a slight schmear of Hylomar on the gasket, and using a jack and a suitably sized board, jack the pan to the engine. Then bolt it up. 1/4" drive extension is helpful. Don't use the bolts to pull it up to the engine.
Front end done?
Peter C
Mojan Mojan Norouzi
Hi Peter,
Thanks for your recommendations.
Is this what you have used?
https://www.amazon.com/Hylomar-Universal-Blue-3-5-Tube/dp/B00XLWUO0A
Yes, it is done smiling smiley
Edited 1 time(s). Last edit at 2018-04-10 04:28 PM by Mojan.
PeterC Avatar
Yep
S1 Elan Kurt. Appley
Akron, Ia., USA   USA
Can't slight Peter's technique but I prefer Aviation Form-a-gasket. Never have figured out why Hylomar became so popular.
Kurt
Mojan Mojan Norouzi
Hi Peter,
Hylomar is non-hardening compound ( non-setting) why you would wait over night ?
PeterC Avatar
Doesn't matter much what sealant. A guy's gotta eat!
Mojan Mojan Norouzi
In reply to # 3714660 by PeterC Doesn't matter much what sealant. A guy's gotta eat!
smiling smiley
Edited 2 time(s). Last edit at 2018-04-11 12:14 AM by Mojan.
daveg Dave G
Hylomar is the way to go. It is not effected by petroleum products, like hot oil and gasoline. You really do not need any sealant if the pan is straight. That is what gaskets are for. Never cut the end corks shorter!
Mojan Mojan Norouzi
In reply to # 3714392 by PeterC Here's a process I've had success using. A slight schmear of Hylomar on the gasket to pan surface. Invert pan on bench. Put a few cinder blocks on it and have dinner. Next day, a slight schmear of Hylomar on the gasket, and using a jack and a suitably sized board, jack the pan to the engine. Then bolt it up. 1/4" drive extension is helpful. Don't use the bolts to pull it up to the engine.
Front end done?
Peter C
Hi Peter,
By the way this is 1275 engine with front an rear gaskets. I’m little concern about where the front and rear gaskets meet the side gaskets.
