I’m renewing rear spring bushings, part#16and14.
Do I need to renew silent bloc part#13?
Rear leaf spring, silent bloc
Posted by Mojan
Mar 28, 2018 10:14 AM
Joined 1 year ago
Bedford, VA, USA
Mar 28, 2018 10:30 AM
![]() Joined 6 years ago
Look at it and see if it has any cracks or signs of wear. You can replace it on the car by using the right diameter sockets and a strong C-clamp.
S1 Elan
Kurt. Appley
Akron, Ia., USA
![]() 1964 Lotus Elan
Mar 28, 2018 04:08 PM
![]() Joined 5 years ago
For 16, go to hard urethane. You'll like what it does for your handling. Once you get the shackles and the axle unbolted you will be able to assess the condition of the Silent blocks much easier. Not as easy of a job and renewing the other parts may be enough.
Kurt
Kurt
66Sprite
David R
Sydney, NSW, Australia
![]() 1966 Austin-Healey Sprite
Mar 28, 2018 04:31 PM
Joined 2 months ago
On mine, with the spring out of the car, I could see and feel enough sloppy movement in the bush to warrant replacement.
Lawrenceville, GA, USA
Mar 28, 2018 09:05 PM
While you have everything apart why not renew both #16 and 13. Are the wear surfaces of # 22 in good shape? If not, need to replace them as well. Once you have done the other parts why not go all the way and replace all suspension parts? Sure will make a difference in the ride and improve the handling too.
Iceman
Atlanta GA
60 AH MK1
62 AH MKII
67 Midget
71 Midget
Iceman
Atlanta GA
60 AH MK1
62 AH MKII
67 Midget
71 Midget
Mar 28, 2018 11:43 PM
Joined 1 year ago
In reply to # 3706483 by ice
I’ll change both 13and 16.
Apr 17, 2018 01:18 AM
Joined 1 year ago
Right after removing the leaf spring the Silent block came off of spring.
The rubber section was almost gone so the inner metal part removed easily. Used gear puller to remove the outer metal part. Driver side is renewed.... will work on the other side maybe next weekend.
Forums
