Su Hs-2 carb throttle spindle leak
Rustytruck Avatar
Rustytruck Dennis M
Little Rock, AR, USA   USA
1974 MG Midget MkIII "Nigel"
I have discovered a leak in my hs2 carbs around the throttle spindle. What I am wondering is has anyone had success with just replacing the spindle and the butterfly or is that a waste of time and should I send the carbs off to have it reamed and oversized spindle installed?
Perdido Avatar
Tuscaloosa, AL, USA   USA
Dennis,
HS2s typically don’t wear on the carb side, just on the brass throttle shaft. An easy way to test it is to remove the butterfly and slide the shaft out noting the fit of the unworn portion. Since the shafts will probably be worn you might as well rebuild them with new jets, etc.
Rut
1970 MGB, Pale Primrose
1967 Triumph TR4a
1966 Triumph TR4a
Rustytruck Avatar
Rustytruck Dennis M
Just took the throttle spindle out and it is obviously worn. I think I will replace it and the butterfly. Thanks for the help.
3416E9A6-62D5-421B-A718-B95B034477C8.jpeg    53.4 KB
Rustytruck Avatar
Rustytruck Dennis M
Already replaced everything else.
