Wire Wheel Grease Caps
littlecars Avatar
littlecars David Bassett
Nashville, TN, USA   USA
1965 MG Midget MkII "Buffoon"
I've finally gotten around to fiddling with my 1965 Midget with wire wheels. I've found references to these things, and I presume they are designed to ride beneath the knockoff cap to retain heavy grease. Are we supposed to load up the "cup" with grease, insert the threaded pin side out, then install the center cap? Are they threaded due to some long-gone missing shop tool? Mine were just hanging in there loose. The car probably hasn't been lubricated since Gerald Ford was in office.
Wire Wheel MG Grease Caps.jpg    18.9 KB
tater salad Avatar
tater salad Gold Member Todd Smith
Charlotte, NC, USA   USA
the threaded portion is to remove them to service the wheel side of business, its so you can put a slide hammer on the threaded post to remove them when its time for an overhaul, and this per say dust cap , yes you can put grease behind it so to keep grease on the bearings, just be careful and not try to install new ones with something threaded on the all thread to install, it wont work, I know, oh I know
Fresno, CA, USA   USA
I Manufacture a tool for this @ www.mossmotors,com Part # 384-935 / Or www.originalduplicates.con Part# 031943 Cheers
S1 Elan Kurt. Appley
Akron, Ia., USA   USA
They should be driven in far enough to cover the cotter pin hole in the splined wheel hub.
Kurt
littlecars Avatar
Rawhide mallet?
zabond Russell Meehan
Neerim East, victoria, Australia   AUS
1966 MG Midget "Bridget"
I used a spark plug socket & extension bar and knocked it in with a hammer, you don't want to hit the threaded rod or you will damage the cap
Russ
highwaydevil David H.
Denver, USA   USA
Ok, I'm going to slightly hijack this thread. I pulled my front rims off, and the grease cap, or what I assume to be the grease cap, fell out into my hand. How are they supposed to be seated, and if mine is as loose as it seems do I need a new one? What may have happened if it's been loose and flopping aorund in there for who knows how long?
Thanks,
David
halloween Gregg B
Sheridan, WY, USA   USA
Weld a nut to a 5/16x4" bolt to remove it, and tap it back in with a socket. They go in pretty easy.
Hi David,
The wire wheel nut won't allow the cap to get lost, so it is sort of OK if it is not real tight in there.
However, if it is so loose it rattles you can try tweaking its outer shape ever so slightly, just enough so it will stick when pressed into the hub and not flop around.
N
a smear of silastic will hold it and also stop any grease getting out onto your wheel
