Well my project escillated quickly...looking at it there was no way I could run new lines with the motor in the car. So 1 hour later it was on the ground. I don't like plumbing, bending lines etc. But I will say this came out pretty nice. I'm not sure it would have been done with one roll (25feet). It would have been close. And you couldn't make any mistakes. Since I didn't like the first routing I had extra to mess up and believe me I messed up a few times. There was no way I could have done them in one shot hence the compression couplers. I need to make a few aluminum pads to sit the lines on so I can clam em down cause of how the fittings sit. But overall I'm very happy with the result. The lines come up right where I need them, and they are away from the exhaust. And Im gonna end up redoing the brake lines when I do he final teardown for paint.
I'm gonna take the opportunity with the motor out to weld up some extra holes and to clearance the starter better and the slave cylinder. Things too close for me than I can get done now. Also gotta get a fuel filter, almost forgot bout that. I'll just use a shad are mid 90s gm filter, the kind with the orings in the end of the line. I'll pick up the fittings this week.
Edited 1 time(s). Last edit at 2018-03-04 06:25 PM by autocomman.
