securing the top when its down
rockhigher Avatar
rockhigher Geoff B
Atkinson, NH, USA   USA
1956 MG MGA
Seems to me that most all convertible tops when down in the MGA have a tendency to slide forward, at least that's been my experience and judging by the dents and mars in the rear of the seats for others, I'd say I'm not the only one with this issue. Before I put my newly upholstered seats back in the car and my new top ( Lord knows when that'll be, so much more to do smiling smiley ) I'd like to know if has anyone fashioned a strap of some sort to loop around the frame of the top and secured it ? I'm thinking of a leather strap on each side ( kind'a like a belt ) and attach it to the rear panel that separates the cockpit from the trunk.....glad to hear ideas on this subject.....
Geoff
Redhawk1689 Avatar
Salina, KS, USA   USA
1958 MG MGA 1500 "Belle"
It's not necessary if you have the windscreen holder attached (which covers the top and frame. I also leave the rear lift-the-dots of the tonneau cover attached to the studs and just fold the tonneau in behind the seats as added protection. It works well and is easy and quick to put up!
Gary E Avatar
The top will not slide forward if you have the spare tire in place. The spare creates a shelf for the top to rest on.
Mitchman2 Avatar
Mitchman2 Mitchell Andrus
Mills River, NC, USA   USA
I've done exactly this. Check Ace hardware for camping gear straps and "D" rings.
The top is cinched up and out of the way, the top irons are pulled back just enough to save the seats. This also makes the package shelf somewhat usable.
'30 Model A Ford
'48 MGTC
'58 MGA
'58 MGA
Top stowage straps 1.jpg    46.2 KB
Top stowage straps 2.jpg    49.6 KB
rockhigher Avatar
rockhigher Geoff B
1956 MG MGA
That's a fabulous idea !! I was going to put some sort of a ring in the rear wall between the cockpit and trunk, but where you installed it above makes even more sense !!!! Thanks again Kemosabe !!
Geoff
wyatt Avatar
wyatt Silver Member Wyatt W
...if you pull if from the center back it has a tendency to let the frame sides jut out and hit the seat sides, big no no
59mgaguy Avatar
59mgaguy John Terschak
Wakeman, OH, USA   USA
1930 Ford Model A "Jenny"
1959 MG 14/28 "Jessie"
1974 MG MGB "Oooops"
Mitch's idea looks very good except that the straps are going across the plastic side windows. Those straps over time will scratch the plastic windows making the window hard to see out of. The YJ jeep rear windows rolled up and was held up by two straps with snaps. Over a period of 6 months you had two wide cloudy stripe down the rear window.
John
Mitchman2 Avatar
In reply to # 3739555 by 59mgaguy Mitch's idea looks very good except that the straps are going across the plastic side windows. Those straps over time will scratch the plastic windows making the window hard to see out of. The YJ jeep rear windows rolled up and was held up by two straps with snaps. Over a period of 6 months you had two wide cloudy stripe down the rear window.
John
Fair enough, picture taken at first fitting. It's been up and down a few times (damned weather), I put cloth over both sides of the windows.
'30 Model A Ford
'48 MGTC
'58 MGA
'58 MGA
MGARuss Avatar
MGARuss Silver Member Russ Sharples
East Windsor, NJ, USA   USA
1960 MG MGA 1600 "Bonnie"
1993 Mazda MX-5 "Bombita"
On my car (a 1960 1600), the spare tire cover is carpeted and the top sits easily and securely on top of the full size spare. This allows stuff to be put on the shelf below. Then the side-curtain bag covers it all up. As someone else said, if you have a "short" tonneau cover and you leave it attached at the back rail, then you can fold it in half and flip it down like the side-curtain bag and that will provide additional protection between the top and the seats. So if you have a full size spare, I don't think you will have any trouble with the top staying in place.
Russ
P1040085.jpg    42.4 KB
IMG_2897.jpg    37.9 KB
