front hub (and rear) identification MGA or MGB
Jaap98 Jaap Meijer
Bridel, Luxembourg, Luxembourg   LUX
thanks! - that's another order for Moss coming upwinking smiley
barneymg Avatar
barneymg Barney Gaylord
If you remove all of the shims, and the bearing is still loose, then you need to replace the bearings. Another possibility is that someone modified the inner race spacer, maybe shortening it to accommodate worn bearings sometime in a past life. Otherwise if the shims were left out, the castellated nut would have to have been left loose as well (not a good situation).
