MGA trunk release
chris Avatar
Pendleton, OR, USA   USA
A neighbor called for help getting into his trunk. I pulled the release, he lifted the luggage rack, and all was good. Not. It used to be that he could pull the rod, wlk to the rear and lift the lid all by himself. Something has changed. I would expect a spring somewhere to push up the lid and hold it so people could get around and lift the lid. Not now. I don't see a spring anywhere for holding the lid up but surely there must be something somewhere. Any help?? Thanks.
Used English car parts.
copernicus Avatar
copernicus Nick Kopernik
Springtime in, CT, USA   USA
There is no mechanical spring. The boot lid rests on a rubber seal which will act like a spring to raise the lid. If you have the wrong type of seal or its dried/worn out, there's not enough push back against the lid and it will barely budge when you pull the release lever.
chris Avatar
Thanks for the reply. The car was painted with new rubber a couple of years ago. Maybe putting some kind of spacer between the trunk lip and the sael will raise it enough to take care of the problem. This just started.
Mitchman2 Avatar
Mitchman2 Mitchell Andrus
Mills River, NC, USA   USA
There are trunk "poppers" that hot rodders use for this and for doors, but as said shouldn't be required. A bit of seal material at the lower edge will do it.
'30 Model A Ford
'48 MGTC
'58 MGA
'58 MGA
ghnl Avatar
Mebane, NC, USA   USA
1961 MG MGA "Calvin"
I pull the trunk lid release then push it back in - this releases the latch then raises the rear edge of the lid. I think there is a return spring in the latch mechanism but it has never been enough to pull the handle back in and push the lid up.
Eric Russell ~ Mebane, NC
3066james Avatar
Amelia, VA, USA   USA
What Eric said is how mine works.
If the rod will stay pulled forward, you should be able to walk around and lift the trunk (boot) lid, prop it open and then go back and push the rod rearward.
chris Avatar
Thanks but it doesn't stay. He's going to try shoving it back in an dif that doesn't work, we'll cut some inner tube to place under the seal at the latch.
Don MGA 1600 Avatar
Rutland, Rutland, USA   USA
Chris,
This has worked in the past.
Have your neighbor pull and hold the latch rod to its full travel while you get a hold on the luggage rack and move it forward (reduce the gap along the top horizontal edge of the trunk and body) and pull up at the same time.
Good luck.
Don
chris Avatar
Don, thanks, but we can get the trunk open, it just takes two people. I want it to open and stay open until someone comes around to the back to get into the trunk.
Gary E Avatar
Or one person with long arms..
barneymg Avatar
barneymg Barney Gaylord
Get the correct boot lid seal, the one that is hollow and very soft so it has some spring to it.
