Brake Lines
Tbird Avatar
Tbird ET Taylor
Land O Sky, NC, USA   USA
Nice article Peter - thanks for the link.
Was lucky enough to have the OEM lines in place on the last few cars I've worked on.
Used the same method as Ron duplicating them - even used most of the original ends.
The K-Tool is similar to the one in the article in that it has dies - just a bit different set up.
You can see 4 of the dies it includes in the pic and they are double - one end has a flat collar while the other end has the bevel also explained in the article.
I must have tried 25-30 flares on the cheapo flaring tools and got maybe one that I was satisfied with. First flare out of the K-Tool was perfect. Also used it on my Dodge truck when I replaced all the hard lines. Takes a little practice. The line I used for the truck was coated so it needed to be positioned a bit further in the die than the standard line I used for the MGA but all in all - the K-Tool has been well worth the money spent.
Not sure what happened to the comparison pic in my post above but I've attached it here again.
ET
DSC05257m2.jpg    11.2 KB
joerberg Avatar
joerberg Silver Member Joe A
Hoosick Falls, NY, USA   USA
Well, it's been some time since I started this thread but I wanted to comment on a recent purchase. I've used a simple, old school Craftsman single flare set of tools for years and never had any problem with brake fittings. However, due in part to the responses on this post, I recently acquired a high quality, older "New Britain Tool" set of double flare tooling for brake lines. I've got to say, it does a far better job of making a perfect flare than the old "Craftsman" tooling. There'll be debate for years to come on bubble vs. flare but I can safely say the double flare, made with quality tooling, is far superior to the old single tools.
