I keep throwing NO.1 connecting rod bearing
Rod H. Avatar
Amity, OR, USA   USA
1964 MG MGB
1968 MG MGB GT
In reply to # 3755277 by Maalfonso12 At the first rebuild that all was previously done.
In reply to # 3755262 by Basil Adams Lots of good ideas but I'd guess that the crank is bent - or cracked. It's time to do more than replace bearings and measure journals. Pull the crank and have it professionally checked for straightness. And while it's out, clean out the block. Best of luck. Basil 707.762.0974 basiladams@yahoo.com
To state the obvious, obviously something was missed. You need some fresh eyes taking a look.
'63 MGB
'68 MGBGT
'80 VW Vanagon Kombi
tigger00 Avatar
tigger00 Rick O
Creedmoor, NC, USA   USA
1974 MG MGB "Queenie"
I would also suggest checking the oil passage in the crank itself.
Running a piece of wire or something like it through the passages may offer a reason for this problem.
Yeah, but that was then, once you had the first bearing failure it is time to do all of that over again, this is not something you can fix without a complete teardown. I agree with Basil I think you probably have crank issue. It's hard to have a knock without crank damage, and this point, regardless of issue found, the block has to properly cleaned,and I would replace the oil cooler if you have one and completely clean ever oil line internally.
