Upgraded SU Carb Heat Shield Suggestions Needed ?
tampaguy Avatar
tampaguy Jack Shea
Elgin, OR, USA   USA
I need help ! My heat shield looks horrible ! Any suggestions on improvements to it would be appreciated...thanks
mg challenged Avatar
mg challenged Silver Member Joe Williams
Dana Point, CA, USA   USA
1963 Elva Courier "Project"
Remove it, straighten it, strip it, and either paint it or have it powder coated. Get new heat insulators also.
tvrgeek Silver Member Scott S
I cut a piece of aluminum matching the shield and pop riveted it with washer spacers on the back side. More efficient that the asbestos they used.
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1976 Triumph TR6
You know...this topic of insulation for heat shield refurbishment has been discussed many times. Don't know if its in the Library but an advanced search (which searches archives) will yield lots, including many pics.
tampaguy Avatar
tampaguy Jack Shea
Elgin, OR, USA   USA
Was interested if anyone had used something other than aluminum for shield, aluminum gets hot quickly, something that would radiate heat away from carbs completely.
Many of us have one of these and there's many discussions on here about them.
Edited 1 time(s). Last edit at 2018-06-13 07:19 PM by MGB567.
jimandcassdavis Avatar
jimandcassdavis Silver Member Jim Davis
Swanton, OH, USA   USA
1976 MG MGB
Paul Copeland in the UK sells new stainless steel laser cut heat shields
Very high quality
paul.7@ntlworld.com
barry s Avatar
1972 MG MGB GT
1976 Triumph TR6
Many different approaches.
HIF4 Heat Shield 001.JPG    45.6 KB
1976 MG MGB
Delivered to US was about $60.
tampaguy Avatar
tampaguy Jack Shea
Elgin, OR, USA   USA
I was told SS transfers heat , not radiate away ?
Steve64B Avatar
Steve64B Steve Opitz
Phoenix, AZ, USA   USA
1966 MG MGB
aussiejohn Avatar
aussiejohn John Potter
Victoria, Australia   AUS
I will agree with Barrie #8. I run a polished stainless heatshield and have had no problems in the very hot conditions where I live.
It works well, looks good and is easy to keep clean.
Tucson, AZ, USA   USA
1967 MG MGB
1967 MG MGB GT
1971 MG MGB GT
I cleaned and painted mine with silver high heat pain. and intend to install header wrap on the back side. I think Dick Morris suggested this a while back.
Paul's heat shield I linked in #6 sits on top of the phenolic spacers so if stainless transfers heat then it's further away from the manifold than a stock heat shield. You don't have to buy it but you did ask for an "upgraded SU carb heat shield suggestion". He does one for HS and HIF.
FWIW I added small heat shields either end of the head as in intense heat and stopped in traffic I suffered vapor lock. I don't believe that happened because of Paul's heat shield rather the conditions I found myself in. Since doing so no further vapor lock.
Edited 1 time(s). Last edit at 2018-06-14 04:26 AM by MGB567.
albeegreen1 Avatar
bordentown, NJ, USA   USA
1972 MG MGB MkIII "ALBERT"
Stainless steel holds heat longer and faster than steel. It's very anti corrosive. A very abrasive metal to machine or grind. I would stay with the stock heat shield like Dick recommends and give a good cleaning and hit it with some high heat spray paint of your choice or powder coat it. People choose stainless so it doesn't rust.
"Be yourself, because everybody else is already taken". - Oscar Wilde.
"If wishes were horses, beggars would ride" - Phineas Quimby.
1977 MG MGB V8 Conversion
