MGB Door Trim Self Tapping Screws
tvrgeek Silver Member Scott S
Gonna make me one of those marking tools! Actually, for $6 I just ordered one.
Not self taping, standard sheet metal but the washer is much smaller than the generic ones, so if that matters, order them from Moss.
tahoe36c Avatar
tahoe36c Paul Hruza
Panama City, FL, USA   USA
1972 MG MGB GT "Tiny Dancer"
2002 Harley-Davidson Dyna
Geez Scott...
I thought everyone knew about hole finders!!! LOL...
Must be the aviation mechanic in my blood. smileys with beer
You will love using it. No more guessing and then cussing because you were wrong!!
tampaguy Avatar
tampaguy Jack Shea
Elgin, OR, USA   USA
Can you explain the use of this tool further
Slips over the top panel. Nub on back slips into the hidden hole and the bushing on top aligns you bit exactly.
Nope, never seen one. I ordered the #40 so it will fit the holes and will redrill larger holes in the door card. I know I should have followed by B-I-L to Oshkosh a few years back.
tdmoe Avatar
tdmoe Gold Member Ted M
Hayesville, NC, USA   USA
1968 MG MGB
Find the hole with the protruding male stud. Slide whatever material between the "yoke" strike the plunger, the new material now has a indentation where the hole needs to be.
Best regards,
Ted
Tri-County British Car Club
Young Harris, GA
Be at war with your vices, at peace with your neighbors, and let every new year find you a better man.
Benjamin Franklin
tahoe36c Avatar
tahoe36c Paul Hruza
Jack,
The tool is normally used for sheetmetal repairs (riveted panels) where there is only access to one side of the material. No way to "find the hole" for the rivets in the patch being applied...
The tool is slipped between the two sheets of metal until the little tip drops into the existing hole. Then the mechanic drills the new hole for the rivet using the guide in the tool. There are different sized hole finders for different sized rivets.
In reply to # 3754923 by tampaguy Can you explain the use of this tool further
Ken Plumstead Avatar
Smithers, BC, Canada   CAN
1968 MG MGC GT
Thanks Chris. That's brilliant.
You just saved me a bunch of time fooling around trying to come up with a tool that would do just that.
Ken
benhutcherson Avatar
1970 MG MGB
This may be unorthodox, but I generally run an 8-32 or 10-32 tap through the holes(whichever is the closest fit) and then put in the matching machine screw.
As has been indicated, though, "self tapping" screws are really only needed for the initial installation and require care when refitting so that you don't cut fresh threads. If I'm not going to tap the hole-as above-I usually replace them with a sheet metal screw with as close of a thread pitch as I can find. If someone has been sloppy with the self tapping screws in the past, you may need to move to a larger diameter-hence why I just go straight to the tap as I mentioned above.
gray Avatar
gray Graham Moore
Duncan
the majority of black trim screws throughout the car are 3/4" in #8 or #10
course there are some individual ones like door capping, rear cappings (GT), heater hose clips.....
i did exactly what you did and just bought a bag of each.
G
ozieagle Avatar
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
In reply to # 3755015 by benhutcherson "self tapping" screws are really only needed for the initial installation and require care when refitting so that you don't cut fresh threads.
The way to fit self tappers, so they don't cut a new thread, is to insert them in the hole, then gently turn them anti clockwise till there is a small clikck, which means the thread has "dropped" into the thread on the hole.
Herb
ozieagle Avatar
Here's an eBay entry for those screws and washers.
Try scanning around them for other options. Found by searching eBay with MGB trim screws.
https://www.ebay.com.au/itm/323-988-GBK3004-MG-MGB-TRIM-KIT-SCREW-SET/121772239133?hash=item1c5a30e91d:g:60wAAOSwVL1WCLNo
Herb
sweep Avatar
sweep Gold Member Chris W
Gosford, NSW, Australia   AUS
1966 MG MGB "Basil"
2013 Volkswagen Tiguan
2015 Audi A3
Works for pretty much ALL threads to stop cross-threading.
In reply to # 3755133 by ozieagle
Herb
1970 MG MGB
In reply to # 3755432 by sweep Works for pretty much ALL threads to stop cross-threading.
Yes, I got in the habit of doing that in my model railroading days where screws often directly go into plastic. Regardless of the screw type, cross-threading is a real issue.
Another way is to dump the ugly screws and use modern plastic or metal clips.
Fresno, CA, USA   USA
WELL Went ahead and made one, just for the “HALIBUT” took more time than it is worth, considering I could have ordered one from Amazon for $10.00 smileys with beer
571B66D2-0629-4A79-8E82-2F869089C9CE.jpeg    35.7 KB
4A89BAEE-2216-48B7-AAE1-3AB673E00BEB.jpeg    28.5 KB
05FC1CE9-567C-436D-913C-1B6AC9319A6E.jpeg    41 KB
