hazard and turn signal not working
mgbeee Avatar
mgbeee Denis L
Montreal, QC, Canada   CAN
Good day Gurus
I have a little problem. My right rear turn signal will not flash.
The three other corners work fine with the hazard and turn signals
as well as the light on the dash.
The bulb is good.
blinker fluid topped up.
Any ideas ?
Thanks
Denis
jaws Avatar
jaws Bud Jaworski
Elyria, OH, USA   USA
Check ground,
neil stern Avatar
Florida, Naples, USA   USA
1980 MG MGB "My Tomato"
Like Bud said But may i add if you put a lot of stuff in trunk Most likely it will catch a ground wire and pull it out Mine are like little round pegs that fit into a round slot
mgbeee Avatar
mgbeee Denis L
Thanks guys
Found the problem, It was disconnected connector in the engine bay.
Thanks
Denis
estevao Avatar
estevao Frank Estevao
Laval, QC, Canada   CAN
Hi Denis
i have the same problem
everything is working except the back driver side turn signal
just wondering where you found the problem under the hood
love the little car and I'm always adding to it. Looking for people that have the same interest in Montreal
Thanks in advance
Frank
mgbeee Avatar
mgbeee Denis L
Hi Frank
I don't know if the wiring is the same for a midget as a MGB.
anyway there was a connector for the white green wire that came undone
it was located on the harness on the right side of the engine bay close to the fire wall
Denis
Sorry Frank I just noticed it's your driver side light
my problem was the passenger side.
Does the light flash with the four ways on ?
Edited 2 time(s). Last edit at 2018-05-20 10:52 AM by mgbeee.
1963 MG MGB MkI
