Headlight switch wiring - picture?
PTAaron Aaron Loynes
Novi, MI, USA   USA
1975 MG MGB
I was poking around behind the dash to see if I could get to a bulb to replace it with a LED bulb... and in the process I popped the headlight switch out and it broke apart. I disconnected it without first taking a picture - now that I put the switch back together I don't know which wire goes to which prong on the switch.
Anyone have a photo, or can you point me to a reference diagram?
Thanks!
EDIT: Found the info. I didn't have my glasses on so I couldn't see the numbers on the terminals on the switch.
Edited 1 time(s). Last edit at 2018-05-16 09:44 PM by PTAaron.
wolflt52 Avatar
wolflt52 Leslie Turner
San Marcos, TX, USA   USA
1973 MG MGB MkIII "Our Fancy Car"
I have found this to be helpful. I downloaded the PDF and print a copy when I am doing some work.
http://www.advanceautowire.com/mgb.pdf
Fairfield, CA, USA   USA
not "helpful" but ESSENTIAL.
In reply to # 3737925 by wolflt52 I have found this to be helpful. I downloaded the PDF and print a copy when I am doing some work.
SUs, Datsun 5-speed
