mgb harmonic balancer
kareski63 Gold Member Peter Kareski
Front Royal, VA, USA   USA
1977 MG MGB "Freddie"
Does anyone out there know where to purchase a harmonic balancer for a 18V engine? I tried Moss, Victoria British, Bee Hive, Roadster Factory, E-bay, Amazon and a few other that MG experience advertises.
Fresno, CA, USA   USA
Peter, is yours missing or need fixing, @ DAMPERDUDES.COM I think they also make new ones ??smileys with beerThey have them. @ damperdudes.NET thumbs up
Edited 1 time(s). Last edit at 2018-05-16 07:44 PM by oleanderjoe.
It could be fixed or replaced, I am not sure how to test it to see if it going bad. My timing mark is way off the mark but it runs like a champ (48 at 3500 rpm). I installed electronic ignition last year and at 32' at 3500 rpm it ran like a dog. Let me try the dudes, Thanks
Joseph,
I just went on line as you suggested and all it did was send me to the same sits I re-searched. The only ones I found was painted used ones from e-bay the others do not carry.
chris Avatar
Pendleton, OR, USA   USA
Huh. Like Joe, I thought that they rebuilt them.
Used English car parts.
SRN402 Avatar
SRN402 Steve Naert
DeWitt, MI, USA   USA
It's been several years, but I had great service from the Damper Doctor (https://www.damperdoctor.com/) with rebuilding the balancer on my 18V
ozieagle Avatar
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
Hi Peter,
Check my reply to your other thread, re vibration.
Herb
Ken Plumstead Avatar
Smithers, BC, Canada   CAN
1968 MG MGC GT
Here ya go. A really nice one.
https://mossmotors.com/harmonic-crank-balancer-5-1-8-diameter
Ken
Fresno, CA, USA   USA
PETER: Being it up to TDC, as viewed thru the Spark Plug hole, compare to the damper marks. I looked at www.damperdudes.NET and it shows reconditioned ones. ????confused smiley
mgblestyle Avatar
mgblestyle Philip Shave
Olympia, WA, USA   USA
Peter, Moss has a new pulley/damper for a good price: https://mossmotors.com/crank-pulley
While the listing says 62-74 it works fine on later 18V motors. Smaller diameter pulley than the original. The new online catalog hides it pretty well. Phil
B-racer Avatar
B-racer Jeff Schlemmer
Shakopee, MN, USA   USA
2014 Dodge Charger
Your problem is that 32 degrees doesn't work well with the late model smog era camshaft and single roller timing chain set. Advance the timing and move on.
jeff@advanceddistributors.com
tomcrause Tom Crause
Springfield, Illinois, USA   USA
Jeff, what would your suggested advanced timing starting point be for the later model cars?
B-racer Avatar
2014 Dodge Charger
Generally speaking, there is no answer to that question. They've all been mucked with to a large extent, and that means you need to experiment until you find the sweet spot for your combination of parts. Its not unheard of for base timing to vary from 8 degrees at idle to 24 degrees at idle, without the vac hooked up. Late model Bs should NOT have manifold sourced vacuum. The vac line runs through the TCSA switch, OR Tee it into the carb port on a Zenith (direct into the carb port with Weber DGVs). Or if its the original 24 degree vac unit, the car will run better with it disconnected.
tvrgeek Silver Member Scott S
All very true which is why I went to a programmable one devil smiley
Jeff, it looks like I ending up what you are talking about except I took out the TCSA switch and run a straight tube from my weber to my distributer vacuum. When I was at a John Twist work session he told me to just bypass the switch.
