3’syncro angle drive removal
Xcore89 Tom M
Fleet, Hampshire, UK   GBR
Hi all, I want to change my speedo cable on my 3 syncro non overdrive gearbox, iv heard rumours of using a longer od cable will allow me to do this?
Is this true for an early car?
Thanks
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
Yes, it is true for early cars. I've had my '67 B for over 46 years now. I used the longer OD cable to eliminate the troublesome angle drive from the system entirely. RAY
MRoadster Avatar
Doylestown, PA, USA   USA
1938 MG TA Tickford "The TA"
1967 MG MGB MkI "The B"
In reply to # 3737398 by Xcore89 Hi all, I want to change my speedo cable on my 3 syncro non overdrive gearbox, iv heard rumours of using a longer od cable will allow me to do this?
Thanks
This is how it will look without the angle drive. This is a 4 sync OD trans but yours will be similar. I used a piece of split tubing to protect the speedo cable from the frame and secured the tubing with a cable tie after the picture was taken. Eliminating the angle drive cured my bouncing speedometer, too.
Undercarriage_1.jpg    39.3 KB
Speedo cable.jpg    25.9 KB
Xcore89 Tom M
Thanks for the reply’s guys, yea my speedos bouncing all over the place, now just got to track down the fabled copper washer!
Once you have the new cable, matching up the washer should be easy. RAY
