Steering lock 73 B roadster
Manxrock Peter Kennaugh
Onchan, Isle of Man, UK   GBR
Hi. I want to deactivate my steering lock. Can I slide my ignition switch further up the steering column to bypass the the slot that engages the steering lock. Thanks
1526485000298210490639.jpg    69.7 KB
Be Coming Avatar
Be Coming Kelvin Dodd
So. Calif., USA   USA
Peter.
The body of the lock indexes to the hole in the column, so it is not going to be that simple. With the lock off the column, you should be able to peen the material around the lock bar to prevent it from pushing out into the hole in the steering shaft.
barry s Avatar
Alexandria, VA, USA   USA
1972 MG MGB GT
1976 Triumph TR6
I saw on this site a method that I successfully used. Its not elegant but seems to work. Cut a small piece out of a beer can or the like to wrap around the column to prevent the lock plunger from entering the column slot.
jjonns74 Avatar
Indianapolis, IN, USA   USA
1974 MG MGB "Athena"
1974 MG MGB "Apollo"
JB Weld the tab in the Unlock position ???
