quick GT carpet question.
Are the wheel arches moulded or just a strategically shaped/cut piece of flat?
If my GT came with them when I bought it they disintegrated when I removed them. Because I've flat decked the rear from the top of the heel board I'm thinking of just buying a roadster carpet set and DIY from there back.
melbaver Avatar
1968 MG MGB "Moneypit"
Ac roadster Boot Set would do the job, and quite cheap. Haven't installed mine yet if you want to make patterns.
Chris Howells
LENZ Avatar
LENZ Jim Barlow
Leominster, MA, USA   USA
1974 MG MGB GT "Murphy"
my wheel hump were semi molded. took quite a bit of contact cement to hold it down
malski Avatar
malski Silver Member Peter Malkin
The GT wheel well covers are one piece whilst the roadster are two piece given the boot/cockpit dividing panel. The cheaper sets require forming/cutting/pleating whilst more expensive ones are pre-formed.
Peter Malkin
NE Victoria
Australia
MGBGTV8 (1977)
MGTC (1949)
Be Coming Avatar
Be Coming Kelvin Dodd
So. Calif., USA   USA
Barrie.
You can use flat carpet, but it will need to have some darts cut and be either sewn or glued down carefully. Even the pre-formed pieces look better with a bit of judicious fitting.
Thanks guys I reckon I'll chance it with some flat (unless the likely supplier of my carpet kit will change out the roadster arch pieces for a pair of GTs - I don't know if theirs are moulded or flat but I needed to know for ordering extra carpet purposes).
tahoe36c Avatar
tahoe36c Paul Hruza
Panama City, FL, USA   USA
1972 MG MGB GT "Tiny Dancer"
2002 Harley-Davidson Dyna
Barrie,
Some suppliers offer transmission tunnel and wheel arches pre-molded, some don't... I am in the process of purchasing the tufted wool kit from Mirror Trim in the UK. They offer their kits either way.
TJS Avatar
TJS T J Smith
Soulbury, Bucks, UK   GBR
I still have all the original carpets and trim, the rear wheel arch covering is flat, glued on and is split vertically, you can just see the seam in the photo.
