Boot cover install
bug88 Avatar
bug88 Silver Member Chas T
south central, IN, USA   USA
1975 MG MGB "Baby"
I know it’s probably as easy as it looks. (Cut holes. Attach fasteners) but I thought I’d ask
Facts don't worry about feelings
2DC6DEB9-C712-491E-8FDA-1EA95DA755A2.jpeg    29.2 KB
chris Avatar
Pendleton, OR, USA   USA
Pretty much. It helps to have the special tool for the lift a dot tabs.
Used English car parts.
kareski63 Gold Member Peter Kareski
Front Royal, VA, USA   USA
1977 MG MGB "Freddie"
All I can tell you is to take your time. For a proper file line up the back fittings and tape them in place so the it will not shift left to right. The do one snap at a time. Do the snap closest to the back fitting first. Do right they go left. Do the next snap, right then left till all are installed. Have a manual hole punch (buy at any fabric store) pieces of wood to close the snaps on (tools should have come with the snaps). Cut your fingernails down, if you don't you will find out why. As I said take your time, It took me about 2 hours and it looks great. With this type of install you cannot make mistakes, starting over is expensive.
GMB3 Avatar
GMB3 Silver Member George Badger
Soquel, CA, USA   USA
1968 MG MGB "1QUICK B"
I suggest start installing the LTD fasteners on the locations nearest the doors. That will center it better.
GEO
Edited 1 time(s). Last edit at 2018-05-15 07:06 PM by GMB3.
bug88 Avatar
1975 MG MGB "Baby"
It came w no directions so......the metal tab in the cover goes under the metal(silver) tab right? If so’ I need to cut the fabric a little to get the silver point under the metal tab.
E5E77E25-20C9-4AFF-8F14-8CC90FBEA7F5.jpeg    24.2 KB
GMB3 Avatar
Soquel, CA, USA   USA
That looks correct. Is it a metal tab or bar that goes across?
You'll want o center the top on those by moving it slightly side to side until it is even. It's suggested, and I agree, leave to top out in the sun for a while to make it more pliable and so you can stretch it when you mount it to the header bar for a nice taut top.
GEO
bug88 Avatar
1975 MG MGB "Baby"
Tab not bar
chris Avatar
In reply to # 3737425 by bug88 Tab not bar
Because it's a boot cover, not a top. The top would have a bar.
Keifer Avatar
Keifer Silver Member Keith Slaten
Searcy, AR, USA   USA
1976 MG MGB "Maggie"
I need one more lift a dot. I hate to buy a whole package for one. Any kdeas?
chris Avatar
Upholstery shop that does boats.
David Willey Avatar
Johnstown, PA, USA   USA
1975 MG MGB ~ For Sale ! ~
1980 MG MGB "Emily"
What's your address, I'll mail you one,
cheers,
David
1978 MG Midget 1500
