Servo heater flap
tvrgeek Silver Member Scott S
I was considering switching to a servo heater valve, but it would be nice to do a servo on the heater door too. Has anyone adapted the servo in a valve to a push rod that could control the door? Gets rid of those Morse cables and stiff knobs.
malski Avatar
malski Silver Member Peter Malkin
In reply to # 3736467 by tvrgeek I was considering switching to a servo heater valve, but it would be nice to do a servo on the heater door too. Has anyone adapted the servo in a valve to a push rod that could control the door? Gets rid of those Morse cables and stiff knobs.
............... and the fresh air vent door should the roller assembly be absent. I think that Herb Adler was looking at something along these lines some time back.
Peter Malkin
NE Victoria
Australia
MGBGTV8 (1977)
MGTC (1949)
I was thinking of the internal door. Spruce Aircraft has a kit, but over $200. I was wondering if a heater valve could be cut off and a lever welded on, but force is an issue. Not sure model airplane servos have the force.
ClassicBiker Avatar
ClassicBiker Steven Meakings
Clinton Township, MI, USA   USA
Scott,
If you mean the door at the bottom of the heater assembly, I've done it. I used a 9 gram servo motor from evil bay as well as a servo tester and a 5V UBEC ( universal battery eliminator circuit). The UBEC will step down voltage from a 6S LiPo for a RC airplane down to 5V volts for the servo (6S is 22 volts). I up graded my heater with the bigger core and a three speed fan motor, I was also going to do the servo water valve, I have it I just haven't installed it yet. Other domestic things got in the way. I'll take some photos of the door servo and post them.
Steven
Just what I was thinking. I'll await the pix, "servo tester" I gather would be the controller. I'll do some googling.
ozieagle Avatar
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
Scott
When I was playing around with using remote locking motors to operate the flaps and central door flap, I think it was you who suggested lawn mower accelerator handle and cable. It would need some lever design to get the correct angles.
Herb
tampaguy Avatar
tampaguy Jack Shea
Elgin, OR, USA   USA
Boy aren’t we getting lazy
