Installation Sequence
melbaver Avatar
1968 MG MGB "Moneypit"
Windscreen and then Dashboard................or...............Dashboard before Windscreen? Reason?
Chris Howells
Ahmed Avatar
Chestermere, AB, Canada   CAN
1958 MG MGA
Not sure aboutt '68 models but usually Windscreen go first then dashboard.
A couple of reasons. First of which is that the bolts for the windscreen are covered by the dashboard. Also allows you to adjust the rake of the windscreen to better fit the quarter lights.
The dashboard is usually independent of the windscreen.
Windscreen for the reasons Ahmed mentions - just easier. And if you have your BMH9508/9 off as well even better. Don't forget to have your centr rod set up with the base plate attached and the screws ready to start as you lower the frame down.
Edited 1 time(s). Last edit at 2018-04-17 02:27 AM by MGB567.
riley1489 Gold Member Bruce H
In reply to # 3718480 by MGB567 Don't forget to have your centr rod set up with the base plate attached and the screws ready to start as you lower the frame down.
this step at installation is paramount thumbs up
don't know if you have the windscreen wiper mechanism installed yet but this install is so much easier without the windscreen and dash installed.
Check your ego Amigo!
melbaver Avatar
Thanks Bruce, wipers in and working, also have to put heater to flap ducting in place before committing to the windscreen and before the dash.
Chris Howells
Ahmed Avatar
1958 MG MGA
Chris,
Dont know if it rains all that much where you are, but a bit of advice is to coat the small oval gaskets under the windshield wiper bases with some silicone on both sides before installation. It is a common place for water to run into the cab and very difficut to diagnose since it is usually never thought of as a source of leak.
Do the same for the windscreen washer nozzles.
Edited 1 time(s). Last edit at 2018-04-18 08:03 PM by Ahmed.
Team DNF Avatar
Team DNF David Dobbins
Kansas City, MO, USA   USA
In reply to # 3719286 by riley1489
Or use screws that are a little shorter than original.
Dave
"Or use screws that are a little shorter than original."
You can do that too; just make sure they're long enough to grab the captive nuts.
