'67 seat frames are different, odd fit
carbus Avatar
carbus Carl Bussler
Havertown, PA, USA   USA
I'm putting new foam in these seats, and when I removed the frame back from the driver's side, it actually sprang apart. It's a very tight fight, and to get the frame back to bolt to the fame bottom requires a good deal of force to compress them together.
This weekend I removed the passenger side and did a comparison. I thought perhaps the back frames were side specific (right goes on right, left on left). I noticed the bends at the bottom of the seat backs look different. The passenger back follows the bottom nicely, whereas the driver side back bows out.
Also, these seats have a threaded bracket at the bottom of the seat back. This is in between the two bolts that adjust seat back inclination. What is this for?
Thanks!
-Carl
1967 MGB GT (Tartan Red)
1972 Yamaha XS650 (Red and White)
2005 Scion XA RS 1.0 #959 of 1550 (Absolutely Red)
passenger-frame.jpg    143.1 KB
driver-frame.jpg    140.7 KB
seat-bracket.jpg    70.8 KB
chris Avatar
Pendleton, OR, USA   USA
Your second picture shows the frame bent/bowed which would change the dimension. The threaded part is for a seat back locking mechanism to keep the seat back locked in position.
Edited 1 time(s). Last edit at 2018-04-16 02:40 PM by chris.
Used English car parts.
carbus Avatar
carbus Carl Bussler
Thanks Chris!
Once you said 'lock' I did a search on here and found another thread where somebody asked a similar question, and you answered them.
Other seat topic here: https://www.mgexp.com/phorum/read.php?1,3124498
So, the mechanism locks the back into place. Got it. Since I've put 3-point seat belts in the GT, I guess I don't need that feature.
But, it's great to learn about these little things!
-Carl
chris Avatar
I'm glad that you brought up that old thread! I wasn't quite right this time. That is indeed the lock part, but I also said that it adjusted the seat which is not correct. That is the job of the two bolts, one on either side of the bottom of the seat back. What a way to adjust a seat!
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
Did I mention, long ago, that they're called seat squabs. RAY
chris Avatar
LOL! That started a whole nuther debate!
Bruce Cunha Avatar
placerville, CA, USA   USA
1950 MG TD
1967 MG MGB GT
My 67 GT does not have any "lock" to keep the back from moving. It has the adjuster.
Bruce E. Cunha
chris Avatar
Then one would guess you have newer seats if you are talking about the type with levers.
Be Coming Avatar
Be Coming Kelvin Dodd
So. Calif., USA   USA
I don't know which seats were fitted with the lock, but there should be a matching, slotted tab on the bottom frame. The lock function was to stop the seat back flopping forward under hard braking and I'm pretty sure only installed on the passenger side. Don't quote me though.
I do know it is important to have during spirited driving. I'm still running stock seats in my 1965 MGB race car and the passenger one definitely needs to be locked down.
Kelvin.
Aridgerunner Avatar
Montoursville, PA, USA   USA
1956 MG MGA 1500 "The A"
Those "J" hooks that Jake showed are truly an either/or lock. Which is not very practical in a GT like my sons. I would think there would be some kind of spring loaded clip that would release with enough hand pressure, but be strong enough to hold the back in place under braking.
The MGA has no lock and under hard braking the passengers seat back will flop forward. I have not yet been able to accelerate hard enough to flip it back into the upright position.
Kelvin, Having owned my '67 B for almost half a century, I can say with some certainty, that my seats are original. Original leather too. My two seat "squabs" were in the glove compartment when I purchased the car from the original owner in '72. Actually, the squabs don't engage any slots, but fit around the bottom of the seat frames. The tops of them have an elongated hole to provide for the adjustment of the seats. Both the drivers and passengers seats were fitted with these units. RAY
1974 MG MGB V8 Conversion
