Need advice. I have a complete front suspension from a 77 MGB that is removed from the car. Any advice on how to disassemble? Can it be done safely without spring compressor?
Mike
Dasassembling Front Suspension Out of Car
Posted by myklos
Endwell, NY, USA
Apr 16, 2018 05:29 AM
Joined 7 years ago
Sunshine Coast, Queensland, Australia
Apr 16, 2018 06:13 AM
![]() ![]() Joined 7 years ago
There is so much previous advice on suspension disassembly - search is your friend. At the risk of opening up the box of popcorn no spring compressor necessary. The springs are under very little tension but there are others who don't believe that and they come up with all sorts of methods to stop the springs going boing. A normal spring compressor doesn't fit.
Apr 16, 2018 08:02 AM
Joined 3 years ago
I have done three sets without a compressor. I attached ratchet straps that you use to tie stuff down with. When releasing the tension it was very anticlimactic. Both times the cross member was still attached to the car, but the engine was out.
Southlake, TX, USA
Apr 16, 2018 08:49 AM
![]() Joined 9 years ago
No need for anything other than an air ratchet or something to undue the 4 shock bolts. Take them off and the shock will 'pop' up a bit but no big deal. Takes about 1 minute to do both sides. You will probably get all kinds of solutions involving some sort of restraint. Nothing is needed.
Pendleton, OR, USA
Apr 16, 2018 10:33 AM
![]() ![]() ![]() Joined 19 years ago
I use a drift to knock out the pin at the top of the shock. Moves about an 1".
Apr 16, 2018 12:20 PM
![]() Joined 11 years ago
Lloyd convinced me to just unbolt the shock bolts many years ago. I will admit that I cringed the first time, but it is a non-event.
So, no, you do not need a spring compressor.
Pete
Pete
Pendleton, OR, USA
Apr 16, 2018 12:32 PM
And no problems messing up the threads doing it that way? That concern is why I use a drift.
Apr 16, 2018 01:59 PM
I did the exact same thing. Used ratchet straps to take up the tension, but there was hardly any. Still, use them anyway just in case.
Apr 16, 2018 02:07 PM
In reply to # 3717972 by chris
Was also a concern when I did it the first time but once again, not an issue.
Pete
Broadwater NSW, Australia
Apr 16, 2018 08:57 PM
![]() ![]() Joined 10 years ago
Easy peasy, see a nut undo it, see a bolt extract it. Only wrenches needed, maybe a rattle gun if the PO was 300 lbs of wrenchmania.
Chris Howells
Chris Howells
Des Moines, IA, USA
![]() 1975 MG MGB
Apr 16, 2018 10:44 PM
Joined 1 year ago
You do however need a spring compressor to put it back together if you don't have an engine in the car. I tried and even with a person standing on the bumper there wasn't enough weight to compress the spring and get the top bolt in. Surprised the heck out of me, of course that was with new springs.
Chris AKA "Defender405"
1975 MGB
1979 Porsche 924
1999 Porsche 996
1987 Nissan 300ZX
1975 MGB
1979 Porsche 924
1999 Porsche 996
1987 Nissan 300ZX
Soling2003
Gary M
Pahoa, HI, USA
![]() 1969 MG MGB MkII
Apr 17, 2018 02:28 AM
Joined 4 years ago
Or a ratchet strap. I put mine back together a few weeks ago with a ratchet strap 1
with the unit off of the car, no problem. I took the springs out without a strap easy. Just moved an inch or so. Did three from different years that way, all a piece of cake. Go for it!
Apr 17, 2018 02:32 AM
"You do however need a spring compressor to put it back together if you don't have an engine in the car"
That may be your Experience but those of us who use the physics that Lloyd outlined oh so many years ago with strategic placement of jack stands at the rear of the leaf springs would suggest otherwise irrespective of engine in or out. Assuming that you're not assembling the front suspension off car. ICR the best method for that exercise but search will know.
Edited 1 time(s). Last edit at 2018-04-17 02:34 AM by MGB567.
Apr 17, 2018 08:11 AM
In reply to # 3718419 by Defender405
Not necessarily (again stolen from Lloyd) put your jacks at the very rear of the car and with judicious of timber planks you can re-install the springs without any compression device. I knew there was a Moment in Physics Class that would come to the rescue.
Chris Howells
Apr 17, 2018 08:12 AM
Apologies Baz, didn't see your post.
Chris Howells
Chris Howells
Forums
