Engine shuts off while driving
jmchugh Jim McHugh
Shelton, CT, USA   USA
I had the same problem with my '79 with an SU conversion. It would happen and then disappear. It turned out to be the wire to the original choke assembly. It would periodically short out. See if you can find an extra wire and tape it off. My two cents.
awjensen467 Avatar
awjensen467 Adam Jensen
Tremonton, UT, USA   USA
Thank you everyone. Lots of good ideas. I will work through them and once diagnosed I will report back. I love this forum. Everyone is extremely helpful.
spikemichael Avatar
Ocean Shores, WA, USA   USA
1973 MG MGB "Freebie"
1974 MG MGB "Spike"
In reply to # 3717726 by Wachtmans Fuel pump. My 2 cents. Get a Hardi electronic one.
I have a hardi.
It pushes 5 PSI
can I pump through it or do I have to remove it and splice the hoses together?
I got a 3PSI pump and it doesn't fit the hole in the trunk correctly.
Michael J. Caputo
spikemichael Avatar
1974 MG MGB "Spike"
Hey Adam,
check your connections at fusebox, specifically the third fuse down, white wire connections.
When it happened to me I would lose turn signals and gauges too. Turned out to be the white's connections to the fusebox, and to each other..
Michael J. Caputo
