bulb size for interior lights please?
MCCT Avatar
MCCT Charles Tisdall
New Zealand, Auckland, New Zealand   NZL
1967 MG MGB
1974 MG MGB GT
HI all,want to renew my interior light bulbs in the 74 Gt..what power should they be please?I tried reverse light bulbs but they are way too big
thanks
CT
IDK which interior light you have there's three here each with a different part number. If you pick your bulb and then look here for dimensions.
Edited 1 time(s). Last edit at 2018-04-16 06:23 AM by MGB567.
riley1489 Gold Member Bruce H
the festoon bulb for your courtesy light should be 5/6 watts. The reverse light is 15 watts.
Check your ego Amigo!
Gokart Avatar
Gokart Silver Member Rob Illingworth
Charles,
Mine are both #29 festoon (GLB239) in the ref to the bulbs only that Barrie gave. They fit into both #10 and #35 fittings in the fist reference.
I went to Jay Car and picked up led replacements. They fit in fairly loosely and the rear one my dog was always knocking so I replaced the whole light with a modern fitting that sits a bit flatter and is not so easy to fall apart.
Cheers Rob
Sorry, I thought the question was 'electrical'
The 'mechanical' answer is 37mm long festoon bulb.
MCCT Avatar
1967 MG MGB
1974 MG MGB GT
Brilliant thanks Guys..I had stuffed up the wiring connections ,so corrected that and they work when doors open now!!
