C pillar
C pillar
  This topic is about my 1979 MG MGB GT V8 Conversion
This is for those who've fitted the extension to the C pillar.
(I can't find who it was that loaded the template) but did you take yours right to the floor base? How did you attach it? Once in what did you do to access the tail light anchoring nuts should you ever have to or do you just assume you'll never need to?
I'm thinking of making both an aluminium and card version.I bolt an angle piece to the floor and attach the aluminium extension up to the original C pillar base. Then attach a card version to that and then if I need access I can just unscrew the base and lift out. Although I have new C pillar covers I have to recover them in Oxford White - I was thinking of just making new C pillar cards that include the extension but I'm not sure which thought is best?????
malski Avatar
malski Silver Member Peter Malkin
I find that the two recesses behind the tail lights on my GT are valuable storage areas. I have no desire to enclose them but understand others reasons for so doing.
Peter Malkin
NE Victoria
Australia
MGBGTV8 (1977)
MGTC (1949)
I've removed the useless rear seat and am in the process of flat flooring that space - two boxes so plenty of storage as well as under the rear floor itself so no need for me to use those spaces.
malski Avatar
In reply to # 3711530 by MGB567 I've removed the useless rear seat and am in the process of flat flooring that space - two boxes so plenty of storage as well as under the rear floor itself so no need for me to use those spaces.
Fair enough. I'm more of a "keep it as original as possible" type than you. Having said that there has never been any human habitation on the rear seats - only luggage and vino.
Peter Malkin
NE Victoria
Australia
MGBGTV8 (1977)
MGTC (1949)
Gerry Avatar
Prairieville, LA, USA   USA
Years ago we had someone here who made a set of fantastic speaker enclosures to fit those cubbies. They were hand laid fiberglass and aimed the speakers in the direction of the front.
If I was going to cover those areas I'd make a panel that would be held in place with some sort of twist latch or maybe even magnets
bencii Ben Colpitts
Mansfield, OH, USA   USA
1966 MG MGB
Vino? Then you must have one of these on the rear window.
20170829_224709.jpg    53.4 KB
Markp61 Avatar
Markp61 Silver Member Mark Pasquill
MARION, MA, USA   USA
Barry. The template includes a tab that sits flat on the trunk floor. The template is also 1 1/2” taller than the bottom of the c pillar cover.
The template is a really good fit. I used thin MDF and scored the bottom tab so it creates a right angle.
When I covered mine with foam , I stopped the foam short of the top of the cover to allow for the overlap with C pillar cover .
I have two self tapping screws in the bottom tab to the trunk floor.
Two flush head screws at the top that are covered by the C pillar cover.
I then created another template to cover the horizontal part. This is covered in the same vinyl and fixed to the frame under the plywood trunk floor.
A3E2318E-1ED8-42B6-980F-A44E815CB963.jpeg    77.7 KB
ED45F2DC-0193-41BC-BB17-1C0F3C5B192C.jpeg    71.9 KB
EA4ECEC4-AA04-4436-AA94-ACF82054880E.jpeg    71.8 KB
gray Avatar
gray Graham Moore
barrie
i think this is the template. on my todo list and speakers/hinged panel are couple of ideas under consideration.
do please inform of progress with pics. i too wonder about the rear seat replace with load space, but it was handy when we had the dog...and may get another....
very nice job you made mark
G
Edited 2 time(s). Last edit at 2018-04-07 03:28 PM by gray.
BGT MAKE REAR Panel.pdf    192.8 KB
Graham. I modified the template such that mine doesn't go to the floor rather it is suspended off the base of the C pillar to about an inch below the rear deck level - that's why there's an angle bracket on the base to act as a support for a filler panel yet to be made. My idea is that I'll cover the extension with a detachable leatherette panel. The extensions are fully detachable so I can get to the tail lights if needs be. last pic is my deck - still requires some fine tuning, hinges, dzus, carpet, trim etc.
P1010606.JPG    43.7 KB
P1010607.JPG    28.7 KB
P1010609.JPG    37.9 KB
P1010608.JPG    43.5 KB
