rear engine plate to transmission
markfavale Avatar
markfavale Mark Favale
Portland, CT, USA   USA
1953 MG TD
Hello All-
Is there a gasket that goes between the rear engine plate and the transmission?
Thanks,
mark
Mark
Portland, CT
53 TD with an 18V
and6412 Andrzej Wojcik
Poland - Krakow, Poland   POL
1965 MG MGB "Crisp"
1976 Mercedes-Benz SLC
NO
Instead, there are gaskets (two) between engine plate and engine itself.
markfavale Avatar
1953 MG TD
thank you!
Mark
Portland, CT
53 TD with an 18V
markfavale Avatar
1953 MG TD
And a follow up question-
I picked up a new rear main seal. Was it a mistake to install it into the plate? Should have I put on the plate first, and then fit it in?
Mark
Portland, CT
53 TD with an 18V
In reply to # 3696398 by markfavale And a follow up question-
No it is common to install with the plate off, Moss makes installation kit for folks to do with the plate intact for engines already assembled, but it is perfectly normal to do this with the plate on the bench. Get something wide, a piece of 2x6 works well and tap it in place, remember to grease the seal lips well before installing the plat onto the block with the seal in place, many seal failures happen at installation because people didn't grease the seal lips.
Edited 1 time(s). Last edit at 2018-03-13 08:50 AM by Speedracer.
http://www.geomatique-liege.be/MGJP/DocumentsPDF/MGB_Workshop_Manual.pdf
Might someone need a manual ?
riley1489 Gold Member Bruce H
In reply to # 3696420 by Speedracer No it is common to install with the plate off, Get something wide, a piece of 2x6 works well and tap it in place, remember to grease the seal lips well before installing the plat onto the block with the seal in place,
Oh yeah the 'old lump of timber' technique, works every time. cool smiley
Pack the spring side of the seal with grease to help support it when installing the plate to engine.
photo courtesy of Haynes
Check your ego Amigo!
BH_backplate_01.JPG    31.2 KB
markfavale Avatar
1953 MG TD
Great. Thanks a lot, everyone.
Mark
Portland, CT
53 TD with an 18V
Ahmed Avatar
Chestermere, AB, Canada   CAN
1958 MG MGA
To add one more question to the topic, I imagine from Bruce photo that the seal should be installed flush with the plate surface (which faces away from the engine). Correct?
In reply to # 3696443 by Ahmed To add one more question to the topic, the seal should be installed flush with the plate surface (which faces away from the engine). Correct?
yes, and don't forget to use the seal retainer plate. winking smiley
Ahmed Avatar
1958 MG MGA
Thanks Bruce.. thumbs up smileys with beer
Did you check for need of a speedi-sleeve ?
