door remote spring
I bought a pair of remotes from Andy Jennings. Unfortunately the LHS has a broken spring. Other than buying another has anyone found a replacement spring - it's the one near the lock not the one on the triangle. I asked Mr G but to no avail.
remote and lock.jpg    23 KB
melbaver Avatar
1968 MG MGB "Moneypit"
I'll take a shufty tomorrow.
Chris Howells
bencii Ben Colpitts
Mansfield, OH, USA   USA
1966 MG MGB
Hi Barrie, that question was recently posted without any favorable responses. I have the same issue and will be making one out of spring material that I have on hand. Another option is to find a hardware store with a good spring selection and modify one to fit. It can be slipped over the pivoting piece so it doesn't need to be made or modified in place.
No luck Melbaver or no shufty yet?
Ben - no spring shops locally.
Now wondering if someone has a busted remote but with the lock end still operative in which case you'd cut that end off the remote and send to me - if so PM me please.
melbaver Avatar
Hi Barrie,
No luck unfortunately. I'm sure one will turn up from somewhere.
Chris Howells
Just what does that spring do - certainly my door won't lock from the inside (but how many use that function)?
The lock mechanism is working and I'm almost certainly going to convert to a remote (as detailed on here by Herb) so maybe I don't need a functioning spring???????????
So if nobody knows what the purpose of the spring is does anyone know what type of spring it is? (You can't see it but it's below.)
spring.jpg    1.6 KB
bencii Ben Colpitts
1966 MG MGB
Barrie, I will take a look later today. I have a broken one as well as a working one on the bench somewhere. I believe the purpose of the spring is to return the lever that engages the locking mechanism to the rest position.
I was asking more now about the type of spring it is - I think it's a compression spring - because when I ask these guys if they have a suitable one they're going to ask.
bencii Ben Colpitts
1966 MG MGB
Torsion. Do you have the old one?
Sorry my bad I meant torsion and yes I still have the busted one on there - I might take it off and either send them a pic or send it to them. I'll keep searching for an equivalent firm locally.
