Rewiring stock vs modern loom?
Gordon Lewis Avatar
Gordon Lewis Silver Member Gordon L
Eureka, CA, USA   USA
1967 MG MGB
I have decided to rewire the 67 because it is having a recurrent problem with the dynamo. There is also some interesting DPO stuff.
I am not overly concerned about stock wiring or new? Is there a significant advantage to the newer wiring kits with more relays ?
Thanks for any advice
Ahmed Avatar
Chestermere, AB, Canada   CAN
1958 MG MGA
New wiring harness (OEM replicas) have no more relays than what originally came with your stock wiring. Any extra relays, fuses, etc are DIY mods added by owners.
But, just by having a new OEM wiring harness, you can expect new insulation on the wires, new (and clean!) bullet connectors, new loom tape, etc. Which, combined with refreshing the existing components connecting to the harness, means years of trouble-free and frustration-free electrical system.
Edited 3 time(s). Last edit at 2018-03-13 11:40 AM by Ahmed.
chris Avatar
Pendleton, OR, USA   USA
Right on what Ahmed said. I haven't ever felt the need for the relays and such, relying instead on new harnesses.
Used English car parts.
Gordon Lewis Avatar
Eureka, CA, USA   USA
1967 MG MGB
Thanks Ahmed and Chris. I’ll order a loom. Just hope I don’t have too many “might as wells” .
I thought you were asking about OEM replacement (think Autosparks) v something like AAW. The former is 'plug and play' provided you get the right year while the latter is a lot more labour intensive eg no bullets pre-fitted.
sandglowB Avatar
sandglowB Silver Member Al Blosser
Uniontown, OH, USA   USA
Go for a modern wiring system. Do you think mg would still be using a 4 fuse panel if they were still building cars. The Prince of darkness reputation didn't come out of nowhere. I drive mine around town and on trips without worrying if it will keep running. I like pure stock and modified MGs, but i want to drive a modern mg.
member - Emerald Necklace MG Register,
NAMGBR since 1991
infantry RVN 1969
Simon Austin Avatar
I’ve had nothing but success using new harnesses available from Autosparks UK. They build the harnesses available from the usual suppliers. They will sell you a factory replica harness or modify as required.
Modern cars use/need all the relays they have due to the complexities of computers built into modern cars. We all know the advantages of relays and there are kits available to add them to a new harness if desired.
Ahmed Avatar
1958 MG MGA
In reply to # 3696247 by Simon Austin I’ve had nothing but success using new harnesses available from Autosparks UK. They build the harnesses available from the usual suppliers. They will sell you a factory replica harness or modify as required.
I did just that. New OEM harness from Autosparks then added a few relays and an upgraded fuse box (8-position). Looks and behaves like stock, but better protected and more reliable.
NOHOME P P
O, ON, Canada   CAN
A 12 circuit harness from Speedway is like $150 ( 200 Cnd) bucks and will do what you need. Arguably better materials and design than the original harness.
I think my cost on a MOSS harness landed in Canada is like $1500 Cnd.
At ten times the cost, the only reason I would go with original is if originality mattered.
If paying, cost to install would be pretty close for either one.
Be Coming Avatar
Be Coming Kelvin Dodd
So. Calif., USA   USA
Gordon.
If you ever have problems with the stock wiring on an MGB, I can fault find it over the telephone.
An aftermarket harness is only as good as the person making the terminations.
Your 67B is a very simple vehicle and doesn't need much in the way of fuses. It is easy to add a couple of extra fused circuits, if you feel you need them and an add on headlight relay kit can just plug into the original harness.
Keep it simple.
Kelvin.
tampaguy Avatar
tampaguy Jack Shea
Elgin, OR, USA   USA
Keep it simple but add relays for headlights, blower and wipers ! Big improvements in functionality
1974 MG MGB MkIII
