battery cable gauge
battery cable gauge
  This topic is about my 1977 MG MGB
sandglowB Avatar
sandglowB Silver Member Al Blosser
Uniontown, OH, USA   USA
Rather than crawl around on the concrete, (I'm old), what is the battery cable's gauge (wire size). I replaced the alternator with a Delco unit and thought maybe I should increase the wire size from the starter to the battery.
member - Emerald Necklace MG Register,
NAMGBR since 1991
infantry RVN 1969
grn78rd Avatar
grn78rd Jon Clark
Clemmons, NC, USA   USA
1971 MG MGB MkII "Mistake"
1978 MG MGB
I recently made a new one for myself using 6 gauge wire obtained at O’Reillys for not too much $.
Fresno, CA, USA   USA
I believe # 4 was Standard. I have used and a lot our members say welding cable. Nice and flexible Cheers
FWIW I asked on Swaps about earth cable. I believe OEM is 4 but it was suggested I'd be better off with 1/0 so I bought a pair from Amazon.
battery cable.jpg    17 KB
tvrgeek Silver Member Scott S
Not only the battery and ground cable, ( I used 1/0) but the hot from the alternator. I use 6 Ga to a 70A fuse, to the fuse block. 8 may be OK, but I like overkill. In spite of some experts here claiming it is impossible, I have seen TWO cars catch fire because they had a dead battery and reved the engine to charge it after a jump with the original brown wires designed for 27 A alternator. ( TR, not MG, but same physics)
I don't like power through mounting bolts, so I run a 6 ga black ground from the alternator case to the block. All these connections should be ring terminals, properly crimped, soldered, and hot-glue heat shrink.
Oh yea, forgot to clarify: The battery cable is not the issue with a new alternator, but it is an issue in the original was just plain too small.
