Anyone used the flashing 1157 bulb replacements?
Jim Stabe Avatar
San Diego, CA, USA   USA
The LED bulbs apparently flash 3 times then come on solid when you hit the brakes. Sounds like a good safety feature if they actually work.
pleblanc1206 Avatar
pleblanc1206 Gold Member Pierre Leblanc
Saline, MI, USA   USA
1974 MG MGB GT "The MG"
2013 Scion FR-S
Jim, I have those on my GT and I agree that they are a great safety improvement. However, several members here have noted that they may not be legal in all states. Personally, I haven't had any run-ins with the law.
1974 MGB-GT: black-label overdrive, essentially stock detoxed engine, Schlemmerized distributor.
warekl Avatar
White Bear Lake Mn, USA   USA
1973 MG MGB GT
I have a flasher that has a delay so that in traffic, you don't drive the person behind you crazy. The flasher doesn't flash the lights unless you haven't hit the brakes for a programmed time, mine being 8 seconds... if the brake lights flash every time you touch the brake pedal in traffic you will drive people nuts....
USMC ... Semper Fi
73 GT in Black Tulip
tbarker7815 Avatar
tbarker7815 Tom .
Knoxville, TN, USA   USA
Wow Keith, 8 seconds seems like a long time before brake lights come on if I understood what you were saying.
Mags MGB Avatar
Mags MGB Platinum Member Greg & Maggie
Troy, IL, USA   USA
1972 MG MGB "Monai"
No,.....they would be on steady for eight seconds, then flash three times, then remain steady
In reply to # 3680870 by tbarker7815 Wow Keith, 8 seconds seems like a long time before brake lights come on if I understood what you were saying.
warekl Avatar
1973 MG MGB GT
No, it means that the brake lights would come on steady, but not flash rapidly 3 times if you had applied the brakes within the last 8 seconds. The brake lights come on but don't strobe/flash.... It's a standard motorcycle accessory. (BackOFF is a popular one and some are programmable for flash and dwell times.)
If the brakes flashed 3 times each time you touched the brakes, say in stop and go traffic, your brake lights would be strobing at the person behind you constantly....
USMC ... Semper Fi
Rod H. Avatar
Amity, OR, USA   USA
1964 MG MGB
1968 MG MGB GT
In reply to # 3680919 by warekl No, it means that the brake lights would come on steady, but not flash rapidly 3 times if you had applied the brakes within the last 8 seconds. The brake lights come on but don't strobe/flash.... It's a standard motorcycle accessory. (BackOFF is a popular one and some are programmable for flash and dwell times.)
The 8 second thing sounds like a good idea. Imagine a freeway full of cars in stop and go with the flashing going on constantly. Would not be good.
'63 MGB
'68 MGBGT
'80 VW Vanagon Kombi
Donthuis Avatar
Donthuis Don van Riet
I guess it is street illegal over here and may let you loose your MoT approval next time. thumbs down
In cases dangerous situations lead to emergency stops on the highway, braking AND activating the hazard flashing on all indicator lights is the approved warning procedure....
PS This reminds me of advanced horn systems where electronics got you seperate tones following each other in quick succession: this feature was immediately forbidden, multi tone horn assembles are required to sound all tones in unison (I am not sure how many simultaneous tones are permitted, the B has an approved double high & low tone setup)
Edited 1 time(s). Last edit at 2018-02-14 03:09 AM by Donthuis.
stevehull Gold Member Steve Hull
Arcadia, OK, USA   USA
Jim, where did you get these flashing bulbs? Cost?
Steve
Steve Hull
Arcadia, OK
73 MGB
405 550 3023
geezer Avatar
Magee, MS, USA   USA
1974 MG MGB GT
Around here it must be illegal to have a following distance of more than 5 feet. Irritating those folks with flashing stop lights sounds like a good idea to me.
Idasix Avatar
Idasix Silver Member David Smailes
Mount Vernon, WA, USA   USA
1975 MG MGB "Red Rider"
I have the flashing rear lights on my LED brakes but I use a module from Superbrightleds.com then I can remove it quickly. Having retired from LE I checked and in my state there is no law forbidding it. Have used them for years. Love em. Step on the brake and it flashes 4 times quickly and then solid on.
Dave
The brave don't live forever...
The cautious don't live at all.
Mustangsix Avatar
Orlando, FL, USA   USA
Most new cars have a flashing third brake light. They blip a couple of times when the brakes are hit. It is not illegal to do that, at least here in FL and I'll bet nearly every other state as well.
rocannon Avatar
1967 MG MGB GT "GT From Hell"
Yup. They flash several times every time the brakes are used. I’ve not found that objectionable in traffic.
Charles, you’ve got that following distance thing right!
In reply to # 3681380 by Mustangsix Most new cars have a flashing third brake light. They blip a couple of times when the brakes are hit. It is not illegal to do that, at least here in FL and I'll bet nearly every other state as well.
TANSTAAFL !
