clutch gear problem
clutch gear problem
  This topic is about my 1973 MG MGB
zab Eric Poelmans
Erembodegem, o-v, Belgium   BEL
1953 Land Rover Minerva
1973 MG MGB "B"ke"
1973 MG MGB GT "Gn'T (Gin N' Tonic)"
1980 Volkswagen Golf Cabriolet
Hi,
In need of the technical know how of the members on this site.
While out driving the other day (1973 MGB UK spec car) all was fine until I had to reverse,
on selecting reverse when releasing the clutch the car stood still, there was a type of grinding noise (sounds to me like 2 surfaces slipping over each other) coming from around the clutch area.
sometimes on reversing sometimes the problem occurs sometimes not, forward no problems or clutch slip(so far).
I am thinking clutch or release bearing, but thinking if it is the clutch then there would be problems in both forward and reverse gears.
I would appreciate your expert input.
Zab
29desoto Avatar
1953 MG TD
1968 MG MGB GT "New Yeller"
1977 MG MGB "Ole Yeller" ~ For Sale ! ~    & more
From the slightly vague description, I'd want to ask a couple of questions?
Did the car move in reverse, or just make the noise? It could be you didn't quite get it all the way into reverse.
And I would think that the clutch would work either way.
Wayne Sanders
Rose Lodge, OR
(TD 4288)
77 MGB - Four tone paint -Pertronix - hood props - cheap tires - new springs all around - mixture of poly and rubber bushings- fuzzy seatcovers - stereo out of old F150 pickup -runs flawlessly and drives nice.
53 TD Mark II - a work in progress.
Steve S. Stephen Strange
Harrisonburg, VA, USA   USA
Eric-
From your description I'd venture that your reverse gear isn't properly engaging.
I bet your car has overdrive.
I bet the unidirectional clutch has failed...
zab Eric Poelmans
1973 MG MGB "B"ke"
thanks guys for the rapid response,
the gearbox (specifically reverse gear), clutch and overdrive will all be investigated, looks like the motor and gearbox will have to come out anyway.
will report back.
Fogliner Avatar
Fogliner Mark Vanherd
Port Clements, BC, Canada   CAN
Remember there is a lockout switch to prevent the OD from engaging in reverse.
Check the switches on the tranny too.
Mark
PB49 Avatar
PB49 Peter B
Marlow, Buckinghamshire, UK   GBR
1978 MG MGB
Had a similarly problem, turned out to be a disintegrated carbon release bearing.
zab Eric Poelmans
1973 MG MGB "B"ke"
Peter,
I think you may be right, I've had a suspicion that the release bearing has been on its last legs for a while now.
Will look into it.
thanks
Eric
