air filters 1975 mgb
jackmcl123 JACK McLELLAN
joggins, NS, Canada   CAN
I would like to convert my 1975 mgb to hs4 su carbs. has anyone come up with a way to get air to the rear carb or what type of air filter system do you use, not much room to put air filter.
Fogliner Avatar
Fogliner Mark Vanherd
Port Clements, BC, Canada   CAN
Have a look at Moss's cold air intake kit.
Regards
Mark
lewk Avatar
Cambridge, ON, Canada   CAN
Here are a couple of ideas that Moss sells for the application you want. Do you have a Moss catalog? K&N filters created especially for the application, the cold air box is supposed to work as well but I'd check with Moss first because in 1975 the motor mounts moved the carb a bit closer to the brake booster than later cars.
untitled.jpg    12.3 KB
223-065_013.JPG    41.5 KB
is the top picture of a 1975
lewk Avatar
Yes. Or you could use these, pancake filters, again available from Moss.
Edited 1 time(s). Last edit at 2017-11-29 10:02 AM by lewk.
IMG_0325.JPG    57.7 KB
not sure which hose go where coming off adsorption canister has air pump removed. could you take picture of canister to carbs.
riley1489 Gold Member Bruce H
forum search is your friend, post #2 at thread below
https://www.mgexp.com/phorum/read.php?1,2186964
Check your ego Amigo!
mowog1 Avatar
Saint Joseph, IL, USA   USA
1969 MG MGC "Vicky"
1972 MG MGB "Mallard"
In reply to # 3636376 by jackmcl123 is the top picture of a 1975
Actually, it is a picture of the K&N filters installed on my 1978 MGB which has HS4 carbs. smiling smiley
Should work on your 1975 as well.
KN Filter #56-9320
I sourced them on Amazon.
mowog1@aol.com
KN Filter 56-9320.jpg    73 KB
K and N Air Filter Taper_1.jpg    79.5 KB
K and N Air Filter Taper_2.jpg    72 KB
K and N Air Filter Taper_3.jpg    60.1 KB
lewisrn Avatar
lewisrn Gold Member Bob L
Danville, IN, USA   USA
1980 MG MGB "The "B"
If you plan to go with the K&N conical filters (56-9320), Amazon sells it for $81 each. Moss (222-985) sells theirs for $105 each.
Anyone who always feels compelled to respond in kind to any perceived slight is often suffering from narcissism.
Cruisedon66 Avatar
Cruisedon66 Pete W
St. Louis, MO, USA   USA
1976 MG MGB
I made my own out of lawn mower filters. (rough first set shown) Instructions in my journal.
Edited 1 time(s). Last edit at 2018-04-17 10:00 AM by Cruisedon66.
Side View 13.jpg    52.7 KB
AF front view.jpg    57.4 KB
Be Coming Avatar
Be Coming Kelvin Dodd
So. Calif., USA   USA
Jack
The Moss 223-065 air intake will clear the 1975 application. We didn't have a 1975 to originally test it so had to guess how much clearance to make and from MG Experience feedback it works.
The tapered K&N filters fit the 1976 onward cars well, but can rub with the 1975 depending on engine mount shimming, sagging etc.
Kelvin.
