Throttle Cable Replaced with Bicycle Cable How To with Pix
spikemichael Avatar
Ocean Shores, WA, USA   USA
1973 MG MGB "Freebie"
1974 MG MGB "Spike"
This job is so easy a six year old could do it.
Allow me to introduce the six year old:
Vincent
Prior to today Vincent has never looked under the hood of a car without being lifted.
Vincent has never worked on a car or repaired or built anything other than LEGOs.
Michael J. Caputo
IMAG1399.jpg    20 KB
spikemichael Avatar
1974 MG MGB "Spike"
Disconnecting the cable at the pedal.
Obviously the PO had replaced the cable at some time.
In order to mimic a roadside repair we re-used the existing fittings as required.
Michael J. Caputo
20170525_125059.jpg    35.6 KB
20170525_125116.jpg    34.5 KB
20170525_125140.jpg    36.1 KB
20170525_125205.jpg    36.7 KB
spikemichael Avatar
1974 MG MGB "Spike"
I provided a little muscle to remove the cable limiter at the carbs. They were out of Vincent's reach.
The cable in the foreground is the choke cable which was not attached.
Michael J. Caputo
20170525_125454.jpg    36.7 KB
20170525_125711.jpg    20.2 KB
spikemichael Avatar
1974 MG MGB "Spike"
just passing the sixteen minute mark.
It takes time to take the photos and when something doesn't come out we have to re-do or re-stage for the camera.
Lighting is difficult because of the bright sunshine and the shadows in the garage.
Here we have Vincent with the defective cable system after removal.
It is laid out for reference while assembling the new cable.
Michael J. Caputo
20170525_130657.jpg    33.2 KB
spikemichael Avatar
1974 MG MGB "Spike"
Opening the bicycle cable package.
We got this at Wal-Mart for $6, though it works just fine it is not as smooth as the replacements from the MG vendors. In fact I eventually sourced a replacement cable and will fit it myself to regain that silky smooth feel under the foot. For this How To we used the roadside available anywhere bike cable.
FWIW we also went through some side procedures because I originally intended to keep the bike cable as the throttle cable.
Michael J. Caputo
20170525_130910.jpg    32.3 KB
spikemichael Avatar
1974 MG MGB "Spike"
Next we removed the fittings from the old cable.
Michael J. Caputo
20170525_131046.jpg    34 KB
20170525_131454.jpg    32.1 KB
20170525_131456.jpg    32.7 KB
20170525_131640.jpg    35.8 KB
20170525_131644.jpg    35.6 KB
spikemichael Avatar
1974 MG MGB "Spike"
A quick look at the gas pedal where the cable attaches to pick among the cables in the bicycle kit.
choosing the cable and checking to see that it will securely rest in the pedal arm.
Michael J. Caputo
20170525_131921.jpg    19.3 KB
20170525_132343.jpg    33.8 KB
20170525_132321.jpg    36.8 KB
spikemichael Avatar
1974 MG MGB "Spike"
Thirty minutes.
Cutting the 'other end' off the replacement cable.
Michael J. Caputo
20170525_132505.jpg    30.5 KB
20170525_132509.jpg    35.4 KB
spikemichael Avatar
1974 MG MGB "Spike"
Adding some leverage... six year old muscles have a hard time with steel cables, the vise grip pliers have a cutter in them and the spring helps him to achieve the necessary 'snap' to sever the cable.
Body weight doesn't hurt the effort!
Michael J. Caputo
20170525_132523.jpg    35.4 KB
spikemichael Avatar
1974 MG MGB "Spike"
After a break for lunch, (Grandma called us in for grilled cheese sandwiches and root beer, followed by a quick trip to the park for an hour with Vincent's little sister...)
We got right back on the job.
The fittings on the end of the bike cable didn't fit inside the fittings we removed from the old cable so they had to go. Roadside you could have made it work but we are in the shop so we took care of it.
once snipped they were sharp.
Michael J. Caputo
GEDC5100_2.jpg    36 KB
GEDC5101_2.jpg    45.4 KB
GEDC5102_2.jpg    30.9 KB
spikemichael Avatar
1974 MG MGB "Spike"
The flash makes the grinder look like it is standing still but it was spinning.
A light touch on the side of the stone cleaned it up very nicely.
Michael J. Caputo
GEDC5103_2.jpg    55.7 KB
spikemichael Avatar
1974 MG MGB "Spike"
Time to fit the old ends to the new cable.
Michael J. Caputo
GEDC5106_2.jpg    38.9 KB
spikemichael Avatar
1974 MG MGB "Spike"
Vincent's assembled cable housing.
Michael J. Caputo
GEDC5108_2.jpg    43.1 KB
spikemichael Avatar
1974 MG MGB "Spike"
Elapsed time forty-eight minutes...
Vincent has threaded the cable through the firewall and slides the housing on the cable.
Michael J. Caputo
GEDC5109_2.jpg    36.9 KB
GEDC5110_2.jpg    35.3 KB
GEDC5111_2.jpg    60.4 KB
GEDC5112_2.jpg    66.2 KB
spikemichael Avatar
1974 MG MGB "Spike"
After placing the cable housing into place (sorry no photos) he threads the adjustment nut in place, followed by the crimp style cable stop.
The crimp stop failed on first pedal depress so don't use them.
I put the old cable stop back on and cut the excess cable for him so we could take it out for a drive while he cleaned up and let grandma know we were leaving.
Michael J. Caputo
GEDC5113_2.jpg    50.7 KB
GEDC5114_2.jpg    59.2 KB
20170525_153015.jpg    38.9 KB
