Is 114.3 the PCD for an MGB?
spikemichael Avatar
Ocean Shores, WA, USA   USA
1973 MG MGB "Freebie"
1974 MG MGB "Spike"
He pulled up an old thread to pop info in on solid mags in the rostyle design for a 4.5" bolt hole 15x6" wheel at about $150.
Designed for the early mustangs.
Wheel Information
Size: 15" x 6"
Lugs: 4 x 4.5"
Finish: Machined with Gloss Black Inserts
Backspacing: 3.75"
Weight: 16.0 lbs.
Center Cap: Included
No idea if the offset is acceptable for the B.
Legendary Wheel Co is in Harrisburg PA
Michael J. Caputo
Welcome Tim. As you're new you're excused for not knowing those rims have been discussed here on and off for about the past year.
Wrong offset, they will muck with the stock fenders.
tvrgeek Silver Member Scott S
So, what is the offset? Does it clear the center hub?
109876543216838 Tim Schuler
Napier, Hawkes Bay, New Zealand   NZL
couple of offsets available for early 4 stud mustangs check cj's pony parts for centre diameter. And they look just like rostyles, I bought a 4.25" set for my Cortina.
V8MGBV8 Avatar
V8MGBV8 Carl Floyd
Kinggsport, TN, USA   USA
They seem to work well with a converted wire wheel B.
https://www.mgexp.com/phorum/read.php?1,3434362,page=6
