TD,TF fuel filter
Mikelead Mike Leadbeater
York, Yorks, UK   GBR
1953 MG TD
Butch
I like your system, best of both worlds.
Not quite sure how you have plumbed it, could you sketch a circuit diagram and post a photo of it ?
Cheers Mike
mgyowner Roland Taras
Hemet, CA, USA   USA
Hello Mike. I've attached a copy of the flow diagram. Pictures are in an above post.
Butch
adapter flow path.jpg    27.2 KB
Good evening Roland, thank you for your clarifications.
But where is this adapter?
Sincerely, Thierry de l'Ardèche, South of France
Hemet, CA, USA   USA
Hello Thierry. It is attached directly to the bottom of the tank between the tank and the fuel line going forward.
Butch
AZTD Avatar
Glendale, AZ, USA   USA
1953 MG TD
But where did you find it?
Unable to locate one
1953 MG TD TD23816
Hemet, CA, USA   USA
Hello Mike. I make them along with a bunch of other items. Contact me off site if you are interested. mgyowner@yahoo.com
Butch
York, Yorks, UK   GBR
1953 MG TD
Butch,
Does the adaptor contain a non return valve, so that either the electronic pump or the SU can draw fuel from the tank?
Cheers
Mike
In reply to # 3905783 by AZTD But where did you find it?
That's what I wanted to ask Roland.
The translation distorted my request ... Thank you Mike.
Hemet, CA, USA   USA
No it does not have a non return valve since I run the pumps in series not parallel.
Butch
York, Yorks, UK   GBR
1953 MG TD
One thing we should consider when using electric fuel pumps is the fitment of an inertia cutoff switch, to stop the pump(s) in the event of an impact.
On previous projects, namely a TR2 and a Sprite, I fitted inertia switches, sourced from eBay and having come from a Landrover. Easy to fit under the dash, wired in to the pump electrical supply.
I don't know what modern cars use, any one any knowledge on these?
Cheers
Mike
+1 Yes No Thank
