T-Series Tips, Tricks, Short-cuts & Cheats
Declan Burns Avatar
Thierry,
Yes to take the rattle out of the gear lever.
Regards
Declan
Oh, yes, but I adapted a spring instead of the one that was broken. Since more problem.
Tim66 Avatar
Tim66 Silver Member Tim Burchfield
Toledo, OH, USA   USA
1951 MG TD
1953 MG TD
Some of you might find this helpful when sorting out your distributor. Most of the information was originally provided by Bob Grunau.
Tim
1951 MG TD TD26711
1953 MG TD TD12524
1980 Corvette
Lucas distributor advance by type.JPG    21.6 KB
cunhab Avatar
cunhab Bruce Cunha
Placerville, CA, USA   USA
1950 MG TD
1967 MG MGB GT
In reply to # 3833707 by jimmac48 I use a piece of scrap oak wood about 1/2 thick. It is notched to fit over the hinges on the tool box and notched on the ends to accept the bonnet. Stores easily behind the tool box with the fuel stick when not in use.
I have the same piece for mine. Only difference is I put felt in the cuts to protect the hood.
Gregory7500 Gregory Serduke
LaGrange, IL, USA   USA
Crude but effective!
Setting the toe using using this method is extremely simple and accurate. Make sure your wood stick is straight, don't over tighten the cable tie to cause deflection. Black marks indicate tire diameter, precisely set with a ruler to 1/8th toe-in.
Gregory s
IMG_2741.JPG    50.8 KB
Tim66 Avatar
Toledo, OH, USA   USA
1951 MG TD
1953 MG TD
Thanks. Does the same thing my expensive store bought rig does.
Tim
1951 MG TD TD26711
1953 MG TD TD12524
1980 Corvette
