Strip of metal under wing edges
  This topic is about my 1953 MG TD
boylanp Avatar
boylanp Paul Boylan
Napier, New Zealand   NZL
1953 MG TD
Hi, what is the purpose of the metal strip that runs along the underside of the wing edges, l removed the strips on my wings because they were rusty, the question is should l replace them or leave them off ? the original strips did look as though they were an after thought.
Thanks Paul B
Buckdendave David Hill
1954 MG TF
Drip rails. They should be there. One of the first things to check if the wings / fenders are as they should be.
Dave H
TD4834 Avatar
TD4834 Bill Chasser
Sacramento, CA, USA   USA
1950 MG TD
1951 MG TD MkII
Yes they should be left in place Helps to deflect moisture and mud from the wire bead
Bill Chasser
TD-4834
TD/c-8151
TD/c-16920
TD-19408
TD-24060
Paul J Avatar
Locust Grove, OK, USA   USA
Here's a picture of a fender/wing off my TF showing the strip. It needs to remain in place to strengthen the edge and deflect water from spraying out from the sides. One on mine had to be replaced which I spot / Tig welded in place to replicate the original welds. Notice the upper fender the strip is off in this pic, I welded a new strip on. PJ
Edited 1 time(s). Last edit at 2018-12-10 07:20 AM by Paul J.
Fender inter strip.jpg    46.9 KB
1954 MG TF
I MIG welded mine to the wired edge very easily.
Dave H
They are welded on mine every 20 cm certainly to strengthen them.
boylanp Avatar
boylanp Paul Boylan
1953 MG TD
Thanks for the replies, at roughly what angle/position should the new strips be welded on.
Paul B
1954 MG TF
Mine are roughly horizontal on the car.
Dave H
The same
img19.JPG    37.6 KB
cbbehr Avatar
cbbehr Cliff Behrend
Tualatin, OR, USA   USA
Fender will shake, vibrate and crack if these are not in place.
boylanp Avatar
boylanp Paul Boylan
1953 MG TD
Thanks again for the info and pictures, l will be refitting them this weekend.
Paul B
Ctwidle Chris Twidle
1954 MG TF
Just started tidying up the wings/fenders on TF 2071 and just need a little advice on these strips.
I can see evidence that they go as far back as the running boards but do they go all the way to the end of the wired edge at the front? I presume they should also be fitted to the running boards and rear wings/fenders?
Thanks in advance,
Chris
Hello Chris,
The front wing with the dimension or stops the wand.
The second which stops at 30 mm
And the rear wing.
Edited 1 time(s). Last edit at 2018-12-17 04:18 AM by MGTF1500 Ardeche France.
IMG_1833.JPG    39.2 KB
IMG_1834.JPG    45.9 KB
IMG_1836.JPG    23.1 KB
1954 MG TF
Merci beacoup Thierry, c’est parfait!
Chris
boylanp Avatar
boylanp Paul Boylan
1953 MG TD
Hi again, is the rear edge of the front valance supposed to line up with inner edge of the wings, it doesn’t look write to me.
2D9D2370-89DD-42BB-A551-2A940EA3301F.jpeg    41.4 KB
350EE0C1-2E4E-4633-ADEE-CF4DB761D23C.jpeg    41.4 KB
1969 MG MGB MkII
