On 54 TF can the rebound buffer be replaced without any disassembly of other front end stuff like springs, control arms, etc.
Looking at it makes me unsure of what is connected to each bolt. Could not find any info in archives.
Thanks in advance, Chuck B.
Rebound rubber buffer
Posted by chunck01
Feb 5, 2019 06:27 PM
Joined 9 months ago
plus4moggie
Tom Lange
Bar Harbor, ME, USA
Feb 5, 2019 06:53 PM
![]() Joined 5 years ago
It's been a while, but as I remember you just have to jack up each side of the suspension to relieve the pressure of the top link on the buffer rubber, and it's a bit awkward. A machine screw and two bolts - do you have the aluminum spacer there already? If not, the new buffers need the spacer, and longer bolts.
I hate to say it, but if the buffers are bad your a-arm bushings are also probably bad, as well as the seals. And then check the shock condition, and the condition of the tubes and bushings in the links. Lots more to say, but don't want to overwhelm.
Tom Lange
MGT Repair
Tom Lange
MGT Repair
Feb 5, 2019 09:26 PM
Joined 9 months ago
Tom,
Had complete front end overhaul, shocks,control arms, tie rods , seals & bushings and bumpers were replaced and all still looks like brand new... however the rubber bumper on driver side seems to have been ripped at the base so I was able to pull it from the location. The bumper on passenger side is fine. , but thought I should replace in pairs.... yes I purchased the spacers you asked about with new bumpers, but was hesitant about starting the work until I know what is going to come apart when I start unscrewing stuff.
Thanks for your help and input. Regards.
Chuck B.
Prescott, AZ.
Chuck B.
Prescott, AZ.
TD4834
Bill Chasser
Sacramento, CA, USA
Feb 5, 2019 11:31 PM
![]() Joined 4 years ago
As long as there is weight on the lower control arm to counter the spring the load will be off the snubber. As Tom relates you will then be able to remove the two bolts on the spacer and the bolt at the top of the snubber and will then come straight out
Bill Chasser
TD-4834
TD/c-8151
TD/c-16920
TD-19408
TD-24060
Bill Chasser
TD-4834
TD/c-8151
TD/c-16920
TD-19408
TD-24060
Forums
MGB & GT ·
MG Midget ·
Buy, Sell & Trade ·
Vendor Market ·
MG Performance ·
MG Engine Swaps ·
Original MG ·
MGA ·
MGC ·
MG Magnette ·
1100 & 1300 ·
T-Series & Prewar ·
Modern MGs ·
MG Motorsports ·
Member Meetup ·
Other Vehicles ·
MG 2019 Event ·
Off Topic ·
Clubs ·
Archived
