MGC Forum
total volts loss
m.s.macrae Murray MacRae
1968 MG MGC
1994 Subaru Impreza WRX
2008 Mazda 6
Hi resistance is what gives you a severe drop in voltage from the "no load" to "load" situations.
you can see if it drops across the battery first, typically if it holds up above 9-10 v on cranking that probably is not your problem.
if it doesn't then progress outwards towards your load. When you are beyond the hi resistance location the voltage drop will be significant.
If you get no volts at a point the issue is a very hi resistance eg an air gap. a disconnection winking smiley.
This advice might help if you are getting confused as the possible source of the problem.
Best of Luck.
Murray
Steve B Avatar
Steve B Silver Member Steve Brannan
Weeki Wachee, FL, USA   USA
I am sure it is not the case here but I discovered a couple of days ago that if the rev counter is disconnected the engine dies ! A loose bullet connector behind the revcounter was responsible
Steve
ROBERT D ROBERT DAVIS
HERTFORDSHIRE, RICKMANSWORTH, UK   GBR
Hi Steve
The tachometer has a white wire loop , pulse pick up via two bullets that supply the 12v to the ignition coil , its surprising how many wires you can disconnect and the car still runs !
Regards
Robert
Davenport, IA, USA   USA
In reply to # 3906830 by ROBERT D Hi Steve
...its surprising how many wires you can disconnect and the car still runs !
Regards
Robert
Indeed, the less touted "magic" of Prince of Darkness, electricity that seemingly flows from the unknown to keep the cars running winking smiley
Regards,
Robert Kirk
kirkbrit@yahoo.com
Business phone 563 323 1017
http://kirks-auto.com/
Moss distributor/UK importer
twentyover Avatar
twentyover Greg Fast
In my case, electricity flows from the river Styx at the gates of hell through my car to return to those nether regions of of tormented souls. Usually carrying some of my soul with it
Edited 1 time(s). Last edit at 2019-03-11 04:07 PM by twentyover.
A bit jaded but sounds right. Also helps to explain no matter what LBC one has, one side is always called earth never thought about it reaching deep earth as Styx but again sounds about right. devil smiley
Regards,
Robert Kirk
kirkbrit@yahoo.com
JMA Avatar
In reply to # 3906943 by twentyover In my case, electricity flows from the river Styx at the gates of hell through my car to return to those nether regions of of tormented souls. Usually carrying some of my soul with it
I'm no poet but that sounds like poetry to mesmileys with beer
