MGC Forum
Arghhh!!! Poly Bushings
Ken Plumstead Avatar
Smithers, BC, Canada   CAN
1968 MG MGC GT
Alright, the bottom kingpin poly bushing defeated me today.
How the hell does one get the spool shaped bushing into the bottom kingpin opening? I almost had it once. There was just about a ¼" of bushing still hung up on the lip but no matter what I tried it would not go into the damn hole.
I tried it with the steel tube in and out. I tried it from both sides. It just does not want to go. Does anyone have the secret to getting it in?
Also, the bushing rim is thicker on one side than the other. What is the correct orientation for it?
Ken
IMG_0779.jpg    64.6 KB
IMG_0780.jpg    47.7 KB
JMA Avatar
As far as orientation is concerned I'll leave that for someone with more knowledge than me.
For fitting the bush I would cut in half and fit the bush in each side of the upright then slide the metal tube in. When the stub axle is bolted up the pressure will hold the two halves in place.
I don't know why SuperPro make their bushes like that but I find it rather annoying.
John
ron neal Avatar
Coastal, SC, USA   USA
1962 MG MGA MkII
1968 MG MGC
1969 MG MGC
1969 MG MGC GT    & more
Ken
You can also use a piece of all thread or a long threaded bolt and an assortment of nuts, washers and sockets to push/pull it through the hole.
Ron
Dandare Avatar
Dandare Danny H
Sydney, Australia   AUS
Is THIS the answer re orientation?
Danny
1968 MG MGC GT
In reply to # 3905307 by ron neal Ken
Ron
Ron,
That's how I was doing it but the bushing always hangs up on one side and then squashes to the side.
Ken
moesignguy Steve Moore
Galena, OH, USA   USA
1963 Triumph TR4 "4"
1968 Triumph Spitfire MkIII "Spit"
1969 MG MGC GT "Da C"
2005 Mini Cooper S "LARG MARG"
Hey Ken,
I pressed new busings in all of the front suspension with a low end / cost 20 ton hydraulic press I got from Harbor Freight. Had to come up with some odd pusher / spacers and used red rubber grease on them to help them along.
HF 20 T PRESS.jpg    32.2 KB
1968 MG MGC GT
In reply to # 3905291 by JMA
John
John,
That was my back up plan that is rapidly gaining strength to becoming the primary plan. I was hoping someone had a 'magic solution' but I guess not.
I'm thinking cutting the bushing shouldn't be a problem with those two giant washers on either side of it once it's installed.
Ken
Edited 1 time(s). Last edit at 2019-03-08 08:42 PM by Ken Plumstead.
Steve S Avatar
A press is definitely the way to do it. Also for the front leaf spring bushes.
Sometimes you can have luck using an old socket and a bench vise, but it's a bit precarious.
Edited 1 time(s). Last edit at 2019-03-08 08:40 PM by Steve S.
1968 MG MGC GT
In reply to # 3905335 by Steve S A press is definitely the way to do it. Also for the front leaf spring bushes.
Steve S,
I have a press and used it on the rear springs. Worked out well. The problem with the king pin hole is the angle it's on. It promotes the bushing to squash to the side where it hangs up.
Sockets aren't deep enough. The bushing is quite tall. A piece of 1 ¼" ID pipe might do the trick.
Ken
1968 MG MGC GT
In reply to # 3905314 by Dandare Is THIS the answer re orientation?
Danny
Thanks Danny,
You are a life saver or a least you saved me from a big search.
Ken
mgcbrian Brian Hutchison
Hampshire, UK   GBR
1968 MG MGC
1969 MG MGC
1969 MG MGC ~ For Sale ! ~
I always cut mine in half. Done this numerous times now without anything adverse happening.
Davenport, IA, USA   USA
On my web site
http://kirks-auto.com/MGC/MGC_specs_and_technical_info_Folder.html
Regards,
Robert Kirk
kirkbrit@yahoo.com
Business phone 563 323 1017
Moss distributor/UK importer
1968 MG MGC GT
Yah, I watched that video and that's what I was attempting to do. Unfortunately I don't have the hand strength (arthritis) like the guy in the video to pull the bushing straight when it squashes to the side.
I'm going to give the press a couple tries and if that doesn't work I'm going to go medieval on it and chop it in half.
Ken
Ken
Use a thread rod and nut with washer/s and "pull" it through sigh ratchet and socket. An 8 foot pipe over the ratchet will make it easy on your tired aged adult hands.
Failed to see the previous recommendation about this from Ron etc. eye rolling smiley
Regards,
Robert Kirk
kirkbrit@yahoo.com
Edited 1 time(s). Last edit at 2019-03-11 03:31 PM by kirks-auto.
