The all-new Front Page News Feed is now live!
Urethane air dam
lewk Avatar
Cambridge, ON, Canada   CAN
I always thought the Special Edition chin spoiler and the air dam in post #13, looked a little bulky, front heavy if you will. Then I spotted the "Richard Grant" chin spoiler from the '70s and thought it much more amenable to the front of a RBB car. I put mine on about 3 years ago now and like the look. Mine is reinforced fiberglass.
This is simply preference. My motto when it comes to our cars is each to his, or her own.
Edited 1 time(s). Last edit at 2019-03-07 09:22 AM by lewk.
IMG_3465.JPG    50.9 KB
IMG_3470.JPG    46.4 KB
Fairfield, CA, USA   USA
the urethane unit will hit a speed bump and not shatter. It will spring back. It is, in effect, a form of rubber. But it does not fold away under any speed an MGB can attain.
SUs, Datsun 5-speed
David H Avatar
Ellensburg, WA, USA   USA
The urethane air dam arrived today.
I ordered it through Jegs website on March 4. It was shipped via FedEx from Anaheim CA on March 8. Arrived today, March 13, in Central Washington.
My observations as I unboxed it.
-It comes with instructions and hardware to attach/bolt it to the stock valance (requires drilling holes in stock valance). I sort of figured that may be the case and I already have a spare junk valance that I will be using.
-There are sanding marks over maybe a third of the air dam. This means I'll have to paint it, I don't want the sanding marks to be seen. It was advertised that it could be used as is, but it's not a uniform color with the sanding marks.
-It seems to be made pretty well. There aren't any gouges or damage that I can find (other than sanding marks which I will have to address when I paint it). It is stiffer than I imagined.
I'll be test fitting it today (if my son takes a nap...).
David
1973 MGB GT
IMG_1391.JPG    58.9 KB
IMG_1392.JPG    23.7 KB
IMG_1388.JPG    52.4 KB
IMG_1390.JPG    48.8 KB
warekl Avatar
White Bear Lake Mn, USA   USA
1973 MG MGB GT
David,
I just removed my valence and drilled holes in the air dam to match those for the valence, then use stainless fender washers and allen screws...
USMC ... Semper Fi
73 GT in Black Tulip
David H Avatar
So I got it mounted, for now. I used the valance mounting holes with the stock/junk valance that I had laying around.
With the stock valance behind it, the air dam is very stiff. It may be too stiff. I want some flex in it since it's urethane. I will take off the front valance and just mount the air dam to see how it feels.
Also, it may be the stock/junk valance or the air dam, but the air dam doesn't cover/reach all the way around the valance piece. You can see in the picture that the stock valance can be seen at the edges of the air dam. If the air dam is stiff enough without the stock valance, this isn't a problem. If it needs the valance, I will try to bend or cut the edges of the valance to hide it behind the air dam.
Overall, I am pleased with my purchase. I actually like it black so I'll just paint it black this spring, when the 8 inches of current snow goes away and it warms up.
David
1973 MGB GT
IMG_1393.JPG    40.2 KB
IMG_1395.JPG    49.7 KB
IMG_1396.JPG    41.4 KB
IMG_1398.JPG    49.7 KB
David H Avatar
In reply to # 3908247 by warekl David,
Sounds like what I plan on trying next. Is it stiff enough? It doesn't seem to floppy?
David
1973 MGB GT
warekl Avatar
1973 MG MGB GT
Really stiff, no problem there. Attaching it to the car helps to stiffen it...
In reply to # 3908254 by David H
USMC ... Semper Fi
David H Avatar
No stock valance neededsmiling smiley Sweet! Works just fine and seems pretty stiff to me. Now to paint it in a couple weeks.
In reply to # 3908292 by warekl Really stiff, no problem there. Attaching it to the car helps to stiffen it...
David
1973 MGB GT
