Thermostat Blanking sleeve
TRex73 Avatar
TRex73 Rex DeShon
Saint Joseph, MO, USA   USA
I have gotten the thermostat housing off and don't see the blanking sleeve. Do I need it? I live in the mid west, in Missouri if that makes any difference.
Tucson, AZ, USA   USA
1967 MG MGB
1967 MG MGB GT
1969 MG MGB MkII
1971 MG MGB GT    & more
Without that or a thermostat, the coolant will flow through the radiator too fast for optimum cooling.
rrmgb Avatar
Reston, VA., USA   USA
If you have a thermostatic switch operating, I'm not sure it is compatible with
a blanking sleeve. Somebody will know. smiling smiley
Sir Winston Churchill
G.S.George PHD
blanking sleeve.JPG    50 KB
rcedward Avatar
rcedward Rob Edwards
Raleigh, NC, USA   USA
1951 MG TD MkII "TDC6000"
1969 MG MGB "182608"
1969 MG MGC GT "8651"
1969 MG MGC GT "8806"    & more
This subject comes up a lot here -- search and ye shall find!
You should be fine with just a thermostat and no blanking sleeve, but you'll probably be better still with both in installed. The sleeve will tend to reduce the amount of water that can bypass the thermostat when the 'stat is open, making sure that more goes through the radiator.
Rob Edwards
Raleigh, NC
http://www.mgcarz.com
If you're in NC, check out the North Carolina MG Car Club!
http://ncmgcc.org
"...good secondhand tools are much better than inferior new ones."
ozieagle Avatar
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
I used a sleeve, once, but quickly got rid of it, as the engine took a very long time to warm up.
Herb
riley1489 Gold Member Bruce H
In reply to # 3888433 by TRex73 I have gotten the thermostat housing off and don't see the blanking sleeve. Do I need it? I live in the mid west, in Missouri if that makes any difference.
No you do not need it.
This blanking sleeve replaces the thermostat (never used in unison) and serves to block the bypass port in the cylinder head. (below) In doing so all the engine coolant will flow through the radiator , (unrestricted by thermostat) at all times.
This situation of course will extend the engine warm up duration, and the engine may never achieve ideal running temperature.
Simply replace the thermostat and go driving.
Check your ego Amigo!
BH_Riley_cylhead-007.jpg    31.1 KB
rcedward Avatar
In reply to # 3888659 by riley1489 This blanking sleeve replaces the thermostat (never used in unison)
Au contraire!
https://www.mgexp.com/forum/mgb-and-gt-forum.1/anyone-using-a-blanking-sleeve-with-their.937414/
And apologies for linking to a different forum, but
http://www.britishcarforum.com/bobmuenchausen/12299.html
Rob Edwards
Raleigh, NC
http://ncmgcc.org
Fair enough.
I have only my great many years using bellows thermostat to rely on.
My hands on experience with these type thermostat and I use bellows type in my engines, (below). The 'temporary blanking sleeve' function only comes into play when the thermostat opens.
This is the best of both worlds, quick warm up and full cooling.
I will not want a full time blanking sleeve in my engines.
Just my take. The OP can do as he wishes.
Edited 1 time(s). Last edit at 2019-02-09 06:19 PM by riley1489.
BH_bellows2.jpg    38.7 KB
"And apologies for linking to a different forum, but"
Why apologise? I was just about to go and search Bob's treatise discussed/linked here many times especially when Bob frequented MGE more than he does now. I run both.
TRex73 Avatar
TRex73 Rex DeShon
thank you so much for the comments. I did find an article by the mg guru that explained it very well that they were used at different times.
Fairfield, CA, USA   USA
the blanking sleeve does not go into my 5-port alloy head....a core shift blocked that opening. I suppose that shifting kinda does what the sleeve was to do.<G>
SUs, Datsun 5-speed
rcedward Avatar
In reply to # 3888838 by MGB567 "And apologies for linking to a different forum, but"
Apologies because it's often considered bad form to link to a "competing" forum. But I wanted to link to Bob's writeup and apparently that's where it now lives....
I run both as well
Rob Edwards
Raleigh, NC
http://ncmgcc.org
Edited 1 time(s). Last edit at 2019-02-09 09:11 PM by rcedward.
Steve S Avatar
Bad form or not, people link to this forum from the others all the time. Fair game. winking smiley
tvrgeek Silver Member Scott S
Emphasis on REDUCE, not block. FWIW, after a new rad and shroud, I have never overheated so have not bothered to install the one on my shelf.
In reply to # 3888599 by rcedward This subject comes up a lot here -- search and ye shall find!
If one were to use both thermostat and this blanking sleeve, I would drill a larger hole in the sleeve and oriented correctly at assembly.
