Thermostat Blanking sleeve
rcedward Avatar
rcedward Rob Edwards
Raleigh, NC, USA   USA
1951 MG TD MkII "TDC6000"
1969 MG MGB "182608"
1969 MG MGC GT "8651"
1969 MG MGC GT "8806"    & more
In reply to # 3888991 by riley1489 If one were to use both thermostat and this blanking sleeve, I would drill a larger hole in the sleeve and oriented correctly at assembly.
Unnecessary. The sleeve does not bottom out in the chamber in the head so with the thermostat closed you'll still have the same flow through the bypass that you would without it. Even when the thermostat is open some coolant will still go around it and through the bypass passages, but less than would without the sleeve.
Rob Edwards
Raleigh, NC
http://www.mgcarz.com
If you're in NC, check out the North Carolina MG Car Club!
http://ncmgcc.org
"...good secondhand tools are much better than inferior new ones."
Donthuis Avatar
Donthuis Don van Riet
Personally I never understood why people would put blanking sleeves in and not just the right thermostat. Checking these thermostats on a regular basis on their opening temps from time to time is wise: two of my older 82C ones open rather late while my (German) old 74C one opens much faster than a brandnew one. Not to forget the newer ones often miss this small bypass hole with a tiny ball inside
Differences in opening and closing temps (hysteresis) over the different thermostats can be much larger than you think! eye rolling smiley
rcedward Avatar
In reply to # 3889045 by Donthuis Personally I never understood why people would put blanking sleeves in and not just the right thermostat.
The thermostat + blanking sleeve idea came about because original-pattern thermostats which close off the bypass are no longer available. I would never run only the blanking sleeve in a street car.
Rob Edwards
Raleigh, NC
http://ncmgcc.org
Edited 2 time(s). Last edit at 2019-02-10 09:24 AM by rcedward.
In reply to # 3889045 by Donthuis Personally I never understood why people would put blanking sleeves in and not just the right thermostat. Checking these thermostats on a regular basis on their opening temps from time to time is wise: two of my older 82C ones open rather late while my (German) old 74C one opens much faster than a brandnew one. Not to forget the newer ones often miss this small bypass hole with a tiny ball inside
Read Bob's write up.
davcar Avatar
davcar Silver Member David Carter
HERVEY BAY, Queensland, Australia   AUS
1969 MG MGB "Peggy-Sue"
1998 MG MGF "Lucy"
In reply to # 3889052 by rcedward
Bellows thermostat now available from Rimmer Bros UK though not cheap. Click link below...!!!
https://rimmerbros.com/Item--i-107590
“Stupid is a condition. Ignorance is a choice.”
Wiley Miller
MGCCQ Wide Bay Chapter Member
Donthuis Avatar
Thanks for the intel, but prices like these put me off I'm afraid, they equal those for electrical fans eye popping smiley
BTW, there is no reference to any application in our B engine, just refs to earlier Triumphs of the MGA era, nor did I find any reference to these older types in Haynes or the factory manual confused smiley
In reply to # 3889510 by davcar
Edited 2 time(s). Last edit at 2019-02-11 10:01 AM by Donthuis.
tvrgeek Silver Member Scott S
I believe the high performance thermostats can be located by just searching Summit:
https://www.summitracing.com/search?SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=thermostat
I found: BRA-330-180 among others.
They seem to be high performance in that they have a larger opening. I think they are all still wax pellet based. Again, to run ad designed by MG in the last century, a sleeve is required. Personally, if my gauge fluctuated a few degrees, who cares as long as it does not overheat.
Curious, in the Morgan and TVR realms I used to be in, ( TR6 and TR-4 engines) this topic never came up and they are probably the most famous cars for overheating as unlike the MG, their systems were inadequate to start with and need all the help they can get. I no longer have any old heads lying around to see.
rcedward Avatar
$88 and way too cold. I'll stick with what I've got thanks!
Rob Edwards
Raleigh, NC
http://ncmgcc.org
$88? How cold is the thermostat. 160 to 190 take your pick.
MG Cruiser Avatar
MG Cruiser Gold Member Keith Delta4
Rockingham, WA, Australia   AUS
1970 MG MGB "Moneypit"
I have fitted the blank and the thermostat. There is strong recommendation that if the car is for road use then if the sleeve is fitted a thermostat should also be used.
Dont be surprised if you have to grind the top shoulder slightly on the sleeve for a good leak free fit. Keith
davcar Avatar
1998 MG MGF "Lucy"
In reply to # 3890139 by MG Cruiser I have fitted the blank and the thermostat. There is strong recommendation that if the car is for road use then if the sleeve is fitted a thermostat should also be used.
Hi Keith
Would appreciate if you could report back on any improvements or differences.
Thanks DC MG
Wiley Miller
All street cars should run a thermostat. ALL. Period. The blanking sleeve is to make the old head design work like a modern thermostat expects. Gad, this is not that hard.
