I'm pretty sure my solenoid has carked it with < 200 starts. I prefer the style below so has anyone found one that will last?
starter solenoid
Posted by MGB567
Sunshine Coast, Queensland, Australia
Feb 12, 2019 01:57 AM
![]() ![]() Joined 8 years ago
North of Seattle, N.W., USA
Feb 12, 2019 02:35 AM
![]() ![]() Joined 7 years ago
Dave ships worldwide
Retain remote or bypass and use the built in
https://www.classiccarperformance.com/
Smaller, faster, lighter...
Feb 12, 2019 03:06 AM
But I don't want a starter I want the inner wheel arch mounted solenoid. I clicked on your link and only see starters. I already have the Aussie version of that.
Carrington, NSW, Australia
Feb 12, 2019 03:11 AM
![]() Joined 11 years ago
I've got the one without the go button, unless you have a screwdriver. Plan on swapping it for the one pictured so I can bump start when tuning.
Chris Howells
Chris Howells
Feb 12, 2019 03:16 AM
In reply to # 3890174 by melbaver
Nah I want to replace with one with a go button - well a big one on the back. There is a small go button on the RH version below but I like the round solenoid.
Feb 12, 2019 05:01 AM
Joined 3 years ago
I always just a generic Ford Bendix and put in a hard wired bump switch. Very reliable.
Feb 12, 2019 05:13 AM
My starter is below and AIUI these are both a starter and a solenoid and is a similar starter to that linked in #2.
If so, the solenoid I show in the OP is really only to provide a go button and a spot for all the wires to be located (on the upper terminal) and a convenience. Astley says if you don't wish to bridge the solenoid terminals with a screwdriver then undo the incoming battery terminal (top) and relocate it to the other terminal with the cable to the starter presumably along with the wires and their spades? That means the solenoid has been taken out of the system so if the car starts you know that it's the solenoid that's the issue - if it doesn't start then it's likely a starter motor issue. Assuming that's what happens and the car starts is there any reason that I can't leave it with the solenoid bypassed until I get a new one?
Feb 12, 2019 05:19 AM
In reply to # 3890182 by tvrgeek
Show me a hard wired bump switch as Dr G wants to show me housing and computer applications. Does a hard wired bump switch allow for an in/out battery cable or is it connected to the starter by a wire? I know some folks who don't have a solenoid mounted under the voltage regulator have installed a switch so that they can bump the tappets - is this what you refer to?
Gosford, NSW, Australia
Feb 12, 2019 05:26 AM
![]() Joined 12 years ago
Barrie, there's a few on Ebay, but they're not cheap.
Local one
Another one.
For mini
Day Dreamers, don't discourage them. That's where original thought comes from.
Local one
Another one.
For mini
Feb 12, 2019 05:31 AM
Thanks S: your 3rd one was on my watch list and now so is the 2nd
I saw the 1st and went looking elsewhere.
Edited 1 time(s). Last edit at 2019-02-12 05:32 AM by MGB567.
Greenville, SC, USA
![]() 1967 MG MGB Racecar "The Biscuit"
Feb 12, 2019 05:49 AM
![]() ![]() ![]() ![]() ![]() Joined 12 years ago
If you are using a gear reduction starter, then it already has one built in, no need for a external unit.
MG/ Triumph Performance Street/Race Engines -
Cylinder Head Porting -
Modified SU HS Carbs -
DIY Engine Rebuild Kits With Free Tech Advice -
VTO alloy wheels for British Sport Cars, and others
Feb 12, 2019 06:13 AM
In reply to # 3890198 by Speedracer
Yeah that's what I thought Hap no need but I have an external one anyway. So rather than run all my wires via the lower terminal on the dead solenoid I could transfer to the starter? Including my quick fuse wire from the alternator?
RAY 67 TOURER
Ray Marloff
Fort Bragg, CA, USA
![]() 1967 MG MGB "My Girl"
Feb 12, 2019 03:17 PM
![]() ![]() ![]() Joined 9 years ago
Barrie, I have a similar set up on my '67 B. It originally used the same solenoid and still does even though I upgraded to a '68 pre-engaged starter motor 35 years ago. I retained the push button fender mounted solenoid and still use it as a relay for the starter motor assembly. Several years ago, an oil line blew out and covered it in very slippery oil. It actually melted the rubber push button cover! I purchased a replacement solenoid from Moss and it's been doing a great job ever since. RAY
malski
Peter Malkin
Bright, N.E.Victoria, Australia
Feb 12, 2019 03:37 PM
Baz
Herb Adler walked me thru the same issue a few weeks back. He’ll probably chime in.
Peter Malkin
NE Victoria
Australia
MGBGTV8 (1977)
MGTC (1949)
Peter Malkin
NE Victoria
Australia
MGBGTV8 (1977)
MGTC (1949)
Feb 12, 2019 05:22 PM
In reply to # 3890205 by MGB567
Belt & Braces, it's the Australian Way!
Chris Howells
Forums
MGB & GT ·
MG Midget ·
Buy, Sell & Trade ·
Vendor Market ·
MG Performance ·
MG Engine Swaps ·
Original MG ·
MGA ·
MGC ·
MG Magnette ·
1100 & 1300 ·
T-Series & Prewar ·
Modern MGs ·
MG Motorsports ·
Member Meetup ·
Other Vehicles ·
MG 2019 Event ·
Off Topic ·
Clubs ·
Archived
