Piston Failure
UMG0251 Avatar
UMG0251 Platinum Member John H Twist
Grand Rapids, MI, USA   USA
1962 MG MGA MkII De-Luxe "The A"
When the rings fail, piston failure follows quickly. This rod is from a late model 18V MGB.
John Twist's famous MG Parts & Service business. We offer bench, line, and restoration services, as well as MG education via DVDs and technical seminars, on-site and off-site.
A-006.JPG    23.4 KB
+2 Yes No Thank
greenrman Gold Member Don B
Kelowna, BC, Canada   CAN
1973 MG MGB "Oscar"
2005 BMW 3 Series Cabriolet "Sabrina"
Hey John, All is not lost. Always a use for things....that is now a conversational coffee table beer coaster knick knack. smileys with beer
PS. Love your videos. Post more, keep the hobby going!
-1 Yes No Thank
tahoe36c Avatar
tahoe36c Paul Hruza
Panama City, FL, USA   USA
1972 MG MGB GT "Tiny Dancer"
2002 Harley-Davidson Dyna
Remember when they used them for ashtrays??? LOL
I'm so glad I don't smoke anymore... Not tobacco anyway!!! LOL...
+1 Yes No Thank
Gerald O Avatar
Gerald O Gerald O'Docharty
1978 MG MGB
That looks familiar.
Edited 1 time(s). Last edit at 2019-03-14 09:40 PM by Gerald O.
Hey John, yep seen that a time, or two in my life, 1275s are notorious for it. This is one thing I always warn about when "re-freshening" a engine using original pistons, is folks often time will sweat the bore condition, and the piston to bore clearances, but completely ignore ring land wear, and this is what excessive ring wear can do. I have seen his in teardown just before it happen as well, when you take the piston out of the bore, the captured ring/s comes out in many pieces.
+1 Yes No Thank
GTgeezer Avatar
GTgeezer Lynn Kirkpatrick
Columbia City, IN, USA   USA
So what happened to the piston in John's picture? Did the ring break and a piece was stuck in the groove for a while, wallowing it out? How long would that have gone on, and would there have been any sign of it? Noise? Blowing oil or smoke?
Same questions on Jerald's.
Just wondering.
The important thing is not to get ahead, but to get along.
Norton Tom Avatar
Norton Tom Thomas Renda
Baltimore, Hon, MD, USA   USA
I thought broken pistons (and rings) were most often caused by just slapping new rings into an irregularly worn bore?
albeegreen1 Avatar
bordentown, NJ, USA   USA
1972 MG MGB MkIII "ALBERT"
They can be mounted and used for trophys for poker runs or for hard luck prizes. Just sayin.
"Only those who have patience to do simple things perfectly ever acquire the skill to do difficult things easily".
- James Corbett.
Gerald O Avatar
1978 MG MGB
Ring breakage can be from:
excess vertical clearance in the ring groove causing excess movement,
ring end-gap too narrow causing ring to seize in the bore when it heats up,
shock loads such as detonation,
bore taper causing excess flex cycling,
installation error, such as hammering the piston down past lack of chamfer at top of bore,
+1 Yes No Thank
RAY 67 TOURER Avatar
RAY 67 TOURER Ray Marloff
Fort Bragg, CA, USA   USA
1967 MG MGB "My Girl"
Rod? You should see the pistons and wrist pins out of a logging truck Diesel engine. The pistons are over 8" in diameter and the wrist pins are solid and 2" in diameter. The pistons make for great ottomans. RAY
Stewart Avatar
Stewart Stewart Langenberg
Santa Barbara, CA, USA   USA
1967 MG MGB GT
1975 MG MGB
been there done that
1975 Mineral Blue MGB Supercharged
1967 Tartanish Red MGB GT Supercharged
Restoration of the 75 MGB Click here
Restoration of the 67 MGB GT Click here
You Can't Prove It Won't Happen
little G Avatar
little G Charlie T
1964 MG MGB "Little G"
I just turn them into lights ...a Cat piston and rod...smoking smiley
20171104_085943.jpg    54.4 KB
20171029_140210.jpg    41.5 KB
20171106_183349.jpg    21 KB
+1 Yes No Thank
Lonwuff Gerald Beach
NAMPA, ID, USA   USA
Back in the day that was an ashtray or business card holder.
NAMPA, ID, USA   USA
I bought a brand new b off the showroom floor in 1974. It had the rubber blocks (don't remember the tech name) on the chrome bumper. The color was mirage and I don't believe they imported many of them. It looked white in the daylight and a very pale purple at night. Anyone have mirage?
1973 MG MGB "Oscar"
In reply to # 3908901 by greenrman Hey John, All is not lost. Always a use for things....that is now a conversational coffee table beer coaster knick knack. smileys with beer
Hmmm. -2 on a genuine #2 post like this ? I suggest Skye has +1/ -1 's representable and accountable to these ying-yangs. Jus sayin.
-1 Yes No Thank
