The all-new Front Page News Feed is now live!
Main harness question
  This topic is about my 1971 MG MGB GT
ron neal Avatar
Coastal, SC, USA   USA
1962 MG MGA MkII
1968 MG MGC
1969 MG MGC
1969 MG MGC GT    & more
Does anyone have a picture or a description of how the main wiring harness is routed and pinned behind the pillow dash. I want to get that routing correct before installing the dash.
Ron
bleteaches6 Avatar
Bonney Lake, WA, USA   USA
Ron
I hope these pictures help from a 79 help. You will find that the wire position of your loom will be determined a lot by the length of the lead to the various devices.
black dash.jpg    53.4 KB
black dash2.jpg    49.2 KB
black dash3.jpg    60.4 KB
ozieagle Avatar
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
This may help you.
Herb
MGB78-WiringLayout.PDF    1.95 MB
polo Mark L
Northern, IN, USA   USA
1960 MG MGA
These are from my 72 B. I have more if needed. Send any questions you may have. Mark
100_1324.JPG    57.4 KB
100_1326.JPG    67 KB
100_1327.JPG    67.3 KB
100_1334.JPG    72.3 KB
+1 Yes No Thank
riley1489 Gold Member Bruce H
Mark L has it thumbs up
The harness just lies there except for the leg at the console P clip.
Check your ego Amigo!
polo Mark L
1960 MG MGA
Yes and it also gets support from the tabs on the back of the dash once its installed. Except for maybe a p clip being used in the wiper motor
area, I don't recall anymore p clips being used. Once the dash is installed the harness gets plenty of support from the the tabs on the
back of the dash . And you can use pull ties if necessary to hang them out of the way if necessary. Here is a picture of the lower tabs that will give
the harness some support. Actually a couple of the metal tabs are used to support the under dash cardboard covers that I sure don't use anymore.
100_1356.JPG    52.9 KB
ron neal Avatar
1962 MG MGA MkII
1968 MG MGC
1969 MG MGC
Appreciate all the info and pictures. I forgot about the tabs on the back of the dash providing the additional support.
Ron
GMDad Avatar
GMDad Silver Member Don Nicholls
Caledonia, Southern Ontario, Canada   CAN
1963 MG MGB
1970 MG MGB "Mellow Yellow"
Mark your picture in post #6 look like you have the dash laying on the bench and the harness plugged into it. Is your dash harness separate from the main harness ? I would like to make my dash removeable with the harness attached to the cluster an then plug it back into the main harness.
Don Nicholls
Ontario Canada
1970 MGB Roadster "mellow"
1963 MGB SCCA Racecar
1940 Chev Street Rod
1965 Chev Pickup restored
"I get to drive them when the wife says I can"
melbaver Avatar
1968 MG MGB "Moneypit"
Don, see my post in your other thread. I thought long and hard about separating the loom at the cockpit/engine-compartment/underside wiring so that I could install a plug on either end, install the dash, get it all tidy then thread through to the engine compartment and just join them together. Apart from he logistics of buying short lengths of colour coded wiring to do this, plus the tedious amount of work to cut and splice so that the two plugs join nicely - there is no spare length in the loom - it is built to fit, there is so much backwards and forwardsing checking each connection that if you got one wire wrong in the two plugs, you'd end up being there forever.
Chris Howells
