Heater Control
Coach Fred Avatar
Coach Fred Fred Birchett
Tappahannock, VA, USA   USA
Didn't realize the end of the heater control was broken until yesterday when I was reassembling the new dash on my 71 B. Moss doesn't have them. Any suggestions of a vendor where I might find one?
Thanks in advance,
Fred
Heater Control.jpg    35.3 KB
Jim Gevay Avatar
Circle Pines, MN, USA   USA
Try "Buy, Sell and Trade" here, or E-bay.
Early 1974 MGB with OD, SU HIF's, 72 spoke chrome WW's, Schlemmer distributor, DuBois fuel pump, Limey's relays, Gerry's column kit.
chris Avatar
Pendleton, OR, USA   USA
Jim x2. I have some floating around here somewhere that may or may not fit.
Used English car parts.
tvrgeek Scott S
The knob/gear controls are unobtanium, so e-bay or whatever. The Morse cables should be available, if not just get a lawn mower cable and make one.
bleteaches6 Avatar
Bonney Lake, WA, USA   USA
What is wrong with the mechanism? I don't see any missing parts other than the cable which is readily available. You might have to soak, clean, and lubricate the mechanism
If you do look for a replacement, look for the number that is stamped into the mechanism frame.
Edited 1 time(s). Last edit at 2019-03-14 01:01 PM by bleteaches6.
allanreeling ALLAN R
The only thing i can't see is the cable nipple. The cables are available. The cable is solid wire so it will push/pull.
soonerv8
